Advisory TFMV-6
Partial tag comparison when using Chacha20-Poly1305 on the PSA driver API interface in CryptoCell enabled platforms
CVE-2023-40271
Public Disclosure Date
04/09/2023
TF-M v1.6.0, TF-M v1.6.1, TF-M v1.7.0, TF-M v1.8.0
Configurations
CC312 enabled platforms, where the legacy driver API is disabled (CC312_LEGACY_DRIVER_API_ENABLED=OFF) and the single part AEAD APIs are implemented through a dedicated function and not by leveraging the multipart functions (CC3XX_CONFIG_ENABLE_AEAD_ONE_SHOT_USE_MULTIPART not set)
It might allow for unauthenticated payloads to be deemed as authentic by comparing only the first 4 bytes of the authentication tag instead of the full length of 16 bytes
2e82124af29b58abcc98608196a63b3c5daf603b, TF-M v1.8.1
Nordic Semiconductor
AEAD algorithms
Authenticated Encryption with Associated Data (AEAD) is a common ciphering method where the data to be encrypted is also authenticated as part of the process by creating an authentication tag. When the encrypted data is then decrypted, the authentication tag is verified and if it does not match the expected value, then the entire operation fails. In this way, the operation allows for Authenticity in addition to the confidentiality granted by the encryption process. Using PSA Crypto APIs, it’s possible to use several of such algorithms, such as AES in Galois-Counter Mode (GCM), AES in Counter with CBC-Mac Mode (CCM) or Chacha20-Poly1305, which is a combination of the Chacha20 cipher with the Poly1305 authenticator [1].
In particular for Chacha20-Poly1305 the corresponding macro defining the algorithm in PSA Cryptographic API specification is PSA_ALG_CHACHA20_POLY1305.
Single part vs multipart API functions
PSA Crypto API specification [2] allows the usage of AEAD algorithms through several possible APIs, that can be grouped generally in the single part, or integrated, operation type, and in the multipart operation type. The main difference is that for single part operations, the whole encryption and tag production (and on the other hand, the whole decryption and tag authentication) happen with a single API call. This type of approach is simpler but at the same time less flexible than the multipart approach where an operation context must be allocated by the application and the encryption/decryption processes require the call to different APIs to setup the operation context, provide inputs to the process and calculate the output. For example, the integrated APIs defined by the PSA Crypto API spec are called psa_aead_encrypt() and psa_aead_decrypt.
It is possible, to reduce the code size of an implementation, to implement the single part APIs by calling the underlying multipart functions, effectively encapsulating the multipart flow in the single part APIs.
PSA Unified Driver API for Cryptoprocessors
The PSA Unified Driver API for Cryptoprocessors spec [3] allows a PSA compliant implementation to redirect some of the operations to the underlying hardware accelerated platform. For example, CryptoCell is a cryptographic accelerator available in some of the TF-M supported platforms that can accelerate crypto operations, such as Chacha20-Poly1305. The driver code associated to it has the responsibility of driving the hardware resources with inputs and collect the outputs. When decrypting, the driver must compare the reconstructed authentication tag with the expected value, and return failure in case of mismatch during verification. For Chacha20-Poly1305, the tag size is 16 bytes.
For CryptoCell enabled platforms, the software component implementing the PSA Unified Driver interface is located into the psa_driver_api directory in lib/ext/cryptocell-312-runtime/codesafe/src/ in TF-M’s codebase. This components can be configured to have single part APIs implemented though the corresponding multipart functions by setting the following define at build time: CC3XX_CONFIG_ENABLE_AEAD_ONE_SHOT_USE_MULTIPART.
By default, CryptoCell enabled platforms don’t build the PSA Unified Driver API interface layer but rely on the legacy interface. To enable the PSA Driver interface the following TF-M build option during CMake config must be be set to OFF: CC312_LEGACY_DRIVER_API_ENABLED=OFF.
When the PSA Driver API interface is used and is not configured to rely on the corresponding multipart functions, when performing the verification of the authentication tag at the end of the authenticated decryption process, the buffer containing the tag is only partially verified (the first 4 bytes only instead of the full 16 bytes). This allows for the possibility of unauthenticated data to be recognized as authentic. An attacker could theoretically construct a malicious payload to actively exploit such partial verification.
Impacted PSA Crypto API functions
The following PSA single part crypto operation function is impacted:
  • psa_aead_decrypt
The verification of the authentication tag must happen on the full 16 bytes of instead of just the first 4 bytes. This means that loop that currently performs such verification in the cc3xx_decrypt_chacha20_poly1305() function must be changed from this:
/* Check tag in "constant-time" */
for (diff = 0, i = 0; i < sizeof(tag_length); i++)
    diff |= tag[i] ^ local_tag_buffer[i];
to this:
for (diff = 0, i = 0; i < tag_length; i++)
Copyright (c) 2023, Arm Limited. All rights reserved.
