NS Agent Mailbox Design
Contact:
The SPE communicates with a remote NSPE through the ‘NS Agent Mailbox’. A physical mailbox mechanism is required for this partition to work.
The NS Agent Mailbox operates like a partition. The agent has an endless loop and waits for signals, calls the FF-M API based on the parsed communication messages.
Because it acts as an agent, you must consider several key design details:
  • The SPM treats the FF-M Client API caller’s ID as the client ID. However, because the NS Agent Mailbox may represent multiple non-secure clients, it must inform SPM which client it represents. The standard FF-M Client API lacks support for this requirement.
  • The FF-M Client API blocks the caller until a reply is received. However, the NS Agent Mailbox must respond to non-secure interrupts promptly. Blocking can delay the handling of non-secure communication messages.
All the concepts for dual-cpu can be extended to multi-cpu without loss of generality. Also see the Hybrid Platform section for further details.
Design
The following figure shows the overall design of the relevant components. NS Agents are implementation-defined components that provide FF-M-compliant Client APIs to non-secure clients. From the client’s perspective, these APIs behave according to the FF-M specification. However, NS Agents require customization and additional handling in the SPM because they carry extra requirements compared to standard secure partitions.
../../_images/mailbox_ns_agent1.svg
Figure 5: High-level agents and secure partitions types and the respective callable API sets into SPM
NS Agent TrustZone is mentioned for the comparison purpose. The implementation details are out of scope for this document.
To align with FF-M compliance, the NS Agent Mailbox is designed to:
  • operate like a standard Secure Partition under the IPC model, with one single thread and the ability to call standard FF-M APIs
  • include a manifest file that describes its attributes and resources
  • be assigned a positive partition ID
Services rely on the client_id for policy enforcement. When the NS Agent Mailbox calls a Client API, the SPM must know which client_id the agent is representing. Since standard APIs treat the caller as the service client, a specific API is needed to support identifying the represented non-secure client.
The SPM sets the non-secure client_id into the message just before it sends the message. Until then, it uses the agent’s ID.
This specific Agent API is non-blocking, unlike the standard FF-M Client APIs. It improves communication efficiency between NS clients and NS Agent Mailbox. This mechanism also requires additional signals and APIs for message acknowledgments.
A standard Secure Partition cannot use the Agent API. If attempted, an error is returned.
Mailbox architecture
The mailbox consists of two components: one in the NSPE and one in the SPE.
The NSPE mailbox handles mailbox functions in the non-secure domain, while the SPE mailbox performs the same functions within TF-M.
On dual-core systems, the NSPE mailbox implements PSA Client APIs by sending client requests and receiving results.
Implementations may differ across NSPE operating systems and use cases.
TF-M provides a reference implementation of the NSPE mailbox.
The NSPE mailbox stores data objects in non-secure memory that hold PSA Client call parameters, return values, and other related data. The NSPE mailbox uses platform-specific inter-process communication (IPC) to handle notifications between the NSPE and the SPE.
The SPE mailbox in TF-M receives requests from the NSPE mailbox, parses them, and invokes the TF-M Remote Procedure Call (RPC) layer. The RPC layer delivers the requests to the TF-M core and Secure Partition Manager (SPM). After the PSA Client call completes, the TF-M core and SPM use the RPC layer to return results to the NSPE through the mailbox. The SPE mailbox manages its objects in secure memory. Both NSPE and SPE mailboxes use platform-specific inter-process communication (IPC) to exchange notifications.
The figure below shows the architecture.
../../_images/multi_cpu_mailbox_arch.png
Figure 6: High-level architecture for SPE and NSPE with mailbox
Mailbox communication for PSA Client calls
NSPE Mailbox queue
The NSPE mailbox maintains a queue in non-secure memory. The queue contains one or more slots, and its size must match that of the SPE mailbox queue. Each slot includes a message and a reply structure. Each slot may also contain fields that identify the non-secure task initiating the PSA Client request. The mailbox message stores the parameters for the PSA Client request inside the slot. The mailbox reply structure receives the PSA Client result from the SPE.
Mailbox messages
In the PSA Client API implementation, the NSPE mailbox selects an empty slot in the queue and writes the parameters into the mailbox message in that slot. The SPE mailbox parses those parameters from the mailbox message. The mailbox message can include additional fields to transfer more information from NSPE to SPE for processing in TF-M.
Mailbox replies
A mailbox reply structure in non-secure memory receives the PSA Client result from the SPE mailbox.
SPE Mailbox queue
The SPE mailbox maintains a queue to store mailbox objects. The number of slots in this queue must match the NSPE mailbox queue. After the SPE is notified of a pending PSA Client request, the mailbox assigns an empty slot, copies the corresponding parameters from non-secure memory, and parses them.
Each slot in SPE mailbox queue can contain the following fields:
  • An optional field to hold mailbox message content copied from non-secure memory.
  • Index of NSPE mailbox queue slot containing the mailbox message.
  • A handle to the mailbox message. Optional. Identify the owner slot of PSA Client result when multiple mailbox messages are under processing.
Additional fields can be included in the slot structure to support mailbox processing in the SPE.
Mailbox notifications between NSPE and SPE
The NSPE mailbox sends a notification to the SPE to signal a pending PSA Client request. In turn, the SPE mailbox notifies the NSPE when the PSA Client result is available. These notifications use platform-specific Inter-Processor Communication (IPC).
To support full-duplex communication between NSPE and SPE, it is recommended to assign a dedicated IPC channel to each notification routine. If both routines share the same IPC channel, proper synchronization must be implemented to prevent conflicts.
In the SPE, the IPC interrupt handler processes notifications from the NSPE and triggers the agent mailbox handling. The communication prototype design [1] defines the behavior of the IPC interrupt handler.
The NSPE can use either an interrupt handler or polling to detect IPC notifications from the SPE.
PSA API and Agent API
The PSA API has been expanded to include:
  • agent_psa_connect()
  • agent_psa_close()
  • agent_psa_call()
To support the behavior changes in these APIs, new signals such as ASYNC_MSG_REPLY and additional types are introduced. The RPC layer uses the Agent API to forward calls to the targeted service.
When non-secure clients call psa_call(), a mailbox message containing its parameters is delivered to the NS Agent Mailbox. The agent extracts the parameters and calls agent_psa_call().
The agent_psa_call() interface takes four arguments, unlike the standard psa_call() which takes six. Some parameters are combined to align the two interfaces.
A composition type is used to pack the vectors:
struct client_params_t {
  int32_t         ns_client_id_stateless;
  const psa_invec *p_invecs;
  psa_outvec      *p_outvecs;
ns_client_id_stateless identifies the non-secure client ID when accessing a stateless service. This value is ignored for connection-based services.
A macro, PARAM_PACK, is introduced to pack vector types and message lengths into a 32-bit control variable:
uint32_t control = PARAM_PACK(params->psa_call_params.type,
                              params->psa_call_params.in_len,
                              params->psa_call_params.out_len);
The agent must indicate whether memory sources for input and output vectors are secure or non-secure. This helps the SPM validate the vectors properly.
To cover the above mentioned scenarios, guidelines are listed for input and output vector processing:
  • The agent needs to tell SPM where vectors and descriptors come from, to assist SPM perform proper memory checking. The source information is encoded in the parameter control.
  • When SPE platforms have the capability to identify the memory sources, platforms can decide whether to skip the indication or not, in the HAL.
Guidelines for vector processing:
  • The agent must inform SPM of the memory origin for each vector and descriptor to enable proper memory checks. This information is encoded in the control parameter.
  • If SPE can determine memory sources independently, it may skip the indication in the HAL.
The agent_psa_connect() and agent_psa_close() functions include an extra ns_client_id parameter to identify the non-secure client. This value must be negative. If the value is zero or positive, SPM ignores it.
This mechanism allows agents to call APIs asynchronously on behalf of the services they represent.
To support the Agent API, the following acknowledgment signal is defined:
#define ASYNC_MSG_REPLY            (0x00000004u)
This signal enables the agent and SPM to manage partition signals, retrieve messages, and handle replies.
Code Example
See the reference implementation of secure_fw/partitions/ns_agent_mailbox/ns_agent_mailbox.c
Custom manifest attributes
Three custom manifest attributes are added for this agent:
Name
ns_agent
Indicates if this partition is an agent (true/false)
client_id_base
The minimum client ID value (<0)
client_id_limit
The maximum client ID value (<0)
client_id_base and client_id_limit are negative numbers. This means that client_id_base <= client_id_limit, but the absolute value of client_id_base must be greater than or equal to that of client_id_limit. SPM checks for overlapping IDs when initializes the secure partitions and agents.
Non-secure callers must provide a negative client ID (<0) when using the PSA API through their communication layer. All NS Agents follow a uniform ID mapping:
NS client ID
Transformed client ID
-1
client_id_limit
-2
client_id_limit - 1
  • (abs(client_id_limit) - abs(client_id_base) + 1)
client_id_base
The functions tfm_multi_core_hal_client_id_translate and tfm_multi_core_register_client_id_range perform this translation.
Any other IDs provided by the NSPE will result in PSA_ERROR_INVALID_ARGUMENT error.
See the reference implementation of secure_fw/partitions/ns_agent_mailbox/ns_agent_mailbox.yaml
Runtime and IDLE processing
At runtime, the NS Agent Mailbox should not be blocked by Agent-specific APIs. It may only be blocked when:
  • calling standard PSA Client APIs
  • calling psa_wait()
Only one component should enter IDLE mode. This depends on system topology:
  • If a TrustZone-based NSPE exists, that NSPE should enter IDLE, regardless of how many NS Agent Mailbox are in the system.
  • If only mailbox-based NSPEs exist, one NS Agent Mailbox can enter IDLE.
The implemented solution:
  • SPRTL provides an API for entering IDLE.
  • Only partitions with a specific flag can call this API.
  • The manifest tooling counts the flagged partitions and returns an error if more than one exists.
Copyright (c) 2022-2025, Arm Limited. All rights reserved.
Copyright (c) 2023 Cypress Semiconductor Corporation (an Infineon company) or an affiliate of Cypress Semiconductor Corporation. All rights reserved.
