Details for the platform/ext folder
This folder has code that has been imported from other projects. This means the files in this folder and subfolders have Apache 2.0 license which is different to BSD 3.0 license applied to the parent TF-M project.
This folder is strictly Apache 2.0 with the exception of cmake files. Maintainers should be consulted if this needs to be revisited.
Sub-folders
accelerator
This folder contains cmake and code files to interact cryptographic accelerators.
In order to use a cryptographic accelerator, a platform must set CRYPTO_HW_ACCELERATOR_TYPE in preload.cmake. This option maps directly to the subdirectories of the accelerator directory. Currently available accelerators are : the CryptoCell cc312, the STMicroelectronics accelerator stm .
A minimal API is exposed to interact with accelerators, the details of this api are in accelerator/interface/crypto_hw.h. Implementation of the API is inside the subdirectory of the individual accelerator.
To configure a cryptographic accelerator at build time, two cmake options can be specified.
  • CRYPTO_HW_ACCELERATOR
    • ON All possible cryptographic operations will be offloaded to the accelerator.
    • OFF The cryptographic accelerator will be ignored and software cryptography will be used.
cmsis
This folder contains core and compiler specific header files imported from the CMSIS_5 project.
common
armclang and gcc
These contain the linker scripts used to configure the memory regions in TF-M regions.
template
This directory contains platform-independent dummy implementations of the interfaces in platform/include. These implementations can be built directly for initial testing of a platform port, or used as a basic template for a real implementation for a particular target. They must not be used in production systems.
driver
This folder contains the headers with CMSIS compliant driver definitions that that TF-M project expects a target to provide.
target_cfg.h
This file is expected to define the following macros respectively.
  • TFM_DRIVER_STDIO - This macro should expand to a structure of type ARM_DRIVER_USART. TFM redirects its standard input and output to this instance of USART.
  • NS_DRIVER_STDIO - This macro should expand to a structure of type ARM_DRIVER_USART. Non-Secure application redirects its standard input and output to this instance of USART.
target
This folder contains the files for individual target. For a buildable target, the directory path from the target directory to its CMakeLists.txt file is the argument that would be given to -DTFM_PLATFORM=.
The standard directory structure is as follows:
  • target
    • <Vendor name>
      • common
      • <buildable target 1>
      • <buildable target 2>
      • <buildable target 3>
Each buildable target must contain the cmake files mandated in the section below.
The common directory is not required, but can be used to contain code that is used by multiple targets.
There must not be any directories inside the vendor directory that is not either the common directory or a buildable platform, to avoid confusion about what directories are a valid TFM_PLATFORM.
Buildable target required cmake files
A buildable target must provide 3 mandatory cmake files. These files must all be placed in the root of the buildable target directory.
preload.cmake
This file contains variable definitions that relate to the underlying hardware of the target.
  • TFM_SYSTEM_PROCESSOR: The processor used by the target. The format is that same as the format used in the -mcpu= argument of GNUARM or ARMCLANG. The special +modifier syntax must not be used.
  • TFM_SYSTEM_ARCHITECTURE: The architecture used by the target. The format is that same as the format used in the -march= argument of GNUARM or ARMCLANG. The special +modifier syntax must not be used.
  • TFM_SYSTEM_DSP: Whether the target has the DSP feature of the given TFM_SYSTEM_PROCESSOR
  • CRYPTO_HW_ACCELERATOR_TYPE: The type of cryptographic accelerator the target has, if it has one. This maps exactly to the subdirectories of platform/ext/accelerator
  • CONFIG_TFM_FP_ARCH: The “FPU architecture” (Armclang) or “FP hardware” (GNU) used by the target for compiling C source files. The value will be transferred to -mfpu argument of GNUARM or ARMCLANG
  • CONFIG_TFM_FP_ARCH_ASM: The “FPU architecture” (Armclang) used by the target for assembling ASM source files. This value will be transferred to the --fpu argument of ARMCLANG. This value is not used by GNUARM.
For more details on CONFIG_TFM_FP_ARCH and CONFIG_TFM_FP_ARCH_ASM, please refer to Floating-Point Support.
Other than these particular cmake variables, it is permissible for the preload.cmake file to contain add_definitions statements, in order for set compile definitions that are global for the hardware. This is commonly used to select a particular set of code from a vendor SDK.
It is not permissible to contains code other than the above in a preload.cmake file, any general cmake code should be placed in CMakeLists.txt and any configuration options should be contained in config.cmake
config.cmake
This file collects platform-specific overrides to the configuration options. This should only contain cmake options that are included in config_base.cmake. These options should be set as CACHE variables, as they are in config_base.cmake.
CMakeLists.txt
This file should contain all other required cmake code for the platform. This primarily consists of the following:
  • Adding an include directory to the target platform_region_defs, which contains the headers flash_layout.h and region_defs.h
  • Adding startup and scatter files to the tfm_s, tfm_ns and bl2 targets.
  • linking CMSIS_5_tfm_ns to the correct version of the CMSIS RTX libraries, as defined in lib/ext/CMSIS_5/CMakeLists.txt
  • Adding required source files, include directories and compile definitions to the platform_s, platform_ns and platform_bl2 targets.
preload_ns.cmake
This optional cmake file is required only if the target runs the NSPE on a core that requires different compiler options than the SPE core. This file has the same format as preload.cmake, but instead details the hardware of the NS core that is not running the main TF-M secure code.
install.cmake
This optional cmake file is required only if additional files need to be installed for the platform.
Flash layout header file
Target must provide a header file, called flash_layout.h, which defines the information explained in the follow subsections. The defines must be named as they are in the subsections.
BL2 bootloader
The BL2 bootloader requires the following definitions:
  • FLASH_BASE_ADDRESS - Defines the first valid address in the flash.
  • FLASH_AREA_BL2_OFFSET - Defines the offset from the flash base address where the BL2 - MCUBOOT area starts.
  • FLASH_AREA_BL2_SIZE - Defines the size of the BL2 area.
  • FLASH_AREA_SCRATCH_OFFSET - Defines the offset from the flash base address where the scratch area starts, which is used during image swapping.
  • FLASH_AREA_SCRATCH_SIZE - Defines the size of the scratch area. The minimal size must be as the biggest sector size in the flash.
  • FLASH_DEV_NAME - Specifies the flash device used by BL2.
The BL2 requires further definitions depending on the number of images, the meaning of these macros are also slightly different:
  • Required definitions in case of 1 image (S and NS images are concatenated and handled together as one binary blob):
    • FLASH_AREA_0_OFFSET - Defines the offset from the flash base address where the primary image area starts, which hosts the active firmware image.
    • FLASH_AREA_0_SIZE - Defines the size of the primary image area.
    • FLASH_AREA_2_OFFSET - Defines the offset from the flash base address where the secondary image area starts, which is a placeholder for new firmware images.
    • FLASH_AREA_2_SIZE - Defines the size of the secondary image area.
  • Required definitions in case of 2 images (S and NS images are handled and updated separately):
    • FLASH_AREA_0_OFFSET - Defines the offset from the flash base address where the primary image areas start, which host the active firmware images. It is also the offset of the primary (active) secure image area.
    • FLASH_AREA_0_SIZE - Defines the size of the primary secure image area.
    • FLASH_AREA_1_OFFSET - Defines the offset from the flash base address where the primary (active) non-secure image area starts.
    • FLASH_AREA_1_SIZE - Defines the size of the primary non-secure image area.
    • FLASH_AREA_2_OFFSET - Defines the offset from the flash base address where the secondary image areas start, which are placeholders for new firmware images. It is also the offset of the secondary secure image area.
    • FLASH_AREA_2_SIZE - Defines the size of the secondary secure image area.
    • FLASH_AREA_3_OFFSET - Defines the offset from the flash base address where the secondary non-secure image area starts.
    • FLASH_AREA_3_SIZE - Defines the size of the secondary non-secure image area.
The table below shows a fraction of the flash layout in case of 2 and 1 updatable images with the related flash areas that hold the firmware images:
Image number: 2
Image number: 1
Flash area
Content
Flash area
Content
FLASH_AREA_0
Secure image
primary slot
FLASH_AREA_0
Secure + Non-secure image
primary slot
FLASH_AREA_1
Non-secure image
primary slot
FLASH_AREA_2
Secure image
secondary slot
FLASH_AREA_2
secondary slot
FLASH_AREA_3
Non-secure image
secondary slot
FLASH_AREA_SCRATCH
Scratch area
FLASH_AREA_SCRATCH
Scratch area
  • IMAGE_EXECUTABLE_RAM_START - Defines the start of the region to which images are allowed to be loaded. Only used if MCUBOOT_UPGRADE_STRATEGY is configured to be RAM_LOAD.
  • IMAGE_EXECUTABLE_RAM_SIZE - Defines the size of the region to which images are allowed to be loaded. Only used if MCUBOOT_UPGRADE_STRATEGY is configured to be RAM_LOAD.
Assemble tool
The assemble.py tool is used to concatenate secure and non-secure binary to a single binary blob. It requires the following definitions:
  • SECURE_IMAGE_OFFSET - Defines the offset from the single binary blob base address, where the secure image starts.
  • SECURE_IMAGE_MAX_SIZE - Defines the maximum size of the secure image area.
  • NON_SECURE_IMAGE_OFFSET - Defines the offset from the single binary blob base address, where the non-secure image starts.
  • NON_SECURE_IMAGE_MAX_SIZE - Defines the maximum size of the non-secure image area.
Image tool
The imgtool.py tool is used to handle the tasks related to signing the binary. It requires the following definition:
  • S_IMAGE_LOAD_ADDRESS - Defines the address to where the Secure (or combined Secure and Non-secure) image is loaded and is executed from. Only used if MCUBOOT_UPGRADE_STRATEGY is configured to be RAM_LOAD.
  • NS_IMAGE_LOAD_ADDRESS - Defines the address to where the Non-secure image is loaded and is executed from. Only used if MCUBOOT_UPGRADE_STRATEGY is configured to be RAM_LOAD and MCUBOOT_IMAGE_NUMBER is greater than 1.
Expose target support for HW components
Services may require HW components to be supported by the target to enable some features (e.g. PS service with rollback protection, etc). The following definitions need to be set in the .cmake file if the target has the following HW components:
  • TARGET_NV_COUNTERS_ENABLE - Specifies that the target has non-volatile (NV) counters.
Copyright (c) 2020-2022 Cypress Semiconductor Corporation (an Infineon company) or an affiliate of Cypress Semiconductor Corporation. All rights reserved. SPDX-FileCopyrightText: Copyright The TrustedFirmware-M Contributors
