Additional build instructions for the IAR toolchain
Follow the instructions in software requirements, but replace the -DTFM_TOOLCHAIN_FILE setting with toolchain_IARARM.cmake.
Notes for building with IARARM
IAR Embedded Workbench for ARM (EWARM) versions v9.30.1 or later are required.
Currently the MUSCA_B1 target is not supported with IARARM, due to lack of testing.
cmake needs to be version 3.21 or newer.
For all configurations and build options some of the QCBOR tests fail due to the tests not handling double float NaN:s according to the Arm Runtime ABI. This should be sorted out in the future.
Example: building TF-M for AN521 platform using IAR:
cd <TF-M base folder>
cmake -S . -B cmake_build -DTFM_PLATFORM=arm/mps2/an521 -DTFM_TOOLCHAIN_FILE=toolchain_IARARM.cmake
cmake --build cmake_build -- install
Alternately using traditional cmake syntax
mkdir cmake_build
cd cmake_build
cmake .. -DTFM_PLATFORM=arm/mps2/an521 -DTFM_TOOLCHAIN_FILE=../toolchain_IARARM.cmake
make install
Regression Tests for the AN521 target platform
cmake -S . -B cmake_build -DTFM_PLATFORM=arm/mps2/an521 -DTFM_TOOLCHAIN_FILE=toolchain_IARARM.cmake -DTEST_S=ON -DTEST_NS=ON
mkdir cmake_build
cd cmake_build
cmake .. -DTFM_PLATFORM=arm/mps2/an521 -DTFM_TOOLCHAIN_FILE=../toolchain_IARARM.cmake -DTEST_S=ON -DTEST_NS=ON
make install
For PSA API tests, you may need to append -DTOOLCHAIN=INHERIT to the build command.
