Adding Secure Partition
Terms and abbreviations
This document uses the following terms and abbreviations.
Table 36: term table
Term
Meaning
FF-M
Firmware Framework for M
ID
Identifier
IPC
Interprocess communication
IPC model
The secure IPC framework
irqs
Interrupt requests
MMIO
Memory Mapped I/O
PSA
Platform Security Architecture
RoT
Root of Trust
SFN
Secure Function
SFN model
Secure Function model
SID
RoT Service ID
SP
Secure Partition
SPM
Secure Partition Manager
TF-M
Trusted firmware M
Secure Partition is an execution environment that provides the following functions to Root of Trust (RoT) Services:
  • Access to resources, protection of its own code and data.
  • Mechanisms to interact with other components in the system.
Each Secure Partition is a single thread of execution and the smallest unit of isolation.
This document mainly describes how to add a secure partition in TF-M and focuses on the configuration, manifest, implement rules. The actual source-level implementation is not included in this document.
If not otherwise specified, the steps are identical for IPC and SFN model.
The IPC and SFN model conforms to the PSA Firmware Framework for M (FF-M) v 1.1 changes. Refer to PSA Firmware Framework specification and Firmware Framework for M 1.1 Extensions for details.
Process
The main steps to add a secure partition are as follows:
Add source folder
Add a source folder under <TF-M base folder>/secure_fw/partitions for the new secure partition (Let’s take example as the folder name):
This folder should include those parts:
  • Manifest file
  • CMake configuration files
  • Source code files
Add manifest
Each Secure Partition must have resource requirements declared in a manifest file. The Secure Partition Manager (SPM) uses the manifest file to assemble and allocate resources within the SPE. The manifest includes the following:
  • A Secure Partition name.
  • A list of implemented RoT Services.
  • Access to other RoT Services.
  • Memory requirements.
  • Scheduling hints.
  • Peripheral memory-mapped I/O regions and interrupts.
The current manifest format in TF-M is “yaml” which is different from the requirement of PSA FF.
The users can set LOW, NORMAL or HIGH in priority attribute in a Secure Partition manifest.
The manifest tool tools/tfm_parse_manifest_list.py calculates the load priority of Secure Partitions based on their priority values and their dependencies. SPM determines the loading and initialization order of Secure Partitions based on their load priority values during TF-M initialization.
  • A Secure Partition with a higher priority is loaded and initialized before Secure Partitions with lower priority.
  • A Secure Partition is loaded and initialized after its dependencies are.
Here is a manifest reference example for the IPC model:
To use SFN model, the user needs to replace "model": "IPC" to "model": "SFN". The user also needs to remove the attribute "entry_point", and optionally replace it with "entry_init".
  "psa_framework_version": 1.1,
  "name": "TFM_SP_EXAMPLE",
  "type": "APPLICATION-ROT",
  "priority": "NORMAL",
  "model": "IPC",
  "entry_point": "tfm_example_main",
  "stack_size": "0x0200",
  "services" : [
      "name": "ROT_A",
      "sid": "0x000000E0",
      "non_secure_clients": true,
      "connection_based": true,
      "version": 1,
      "version_policy": "STRICT"
      "mm_iovec": "disable"
  "mmio_regions": [
      "name": "TFM_PERIPHERAL_A",
      "permission": "READ-WRITE"
  "irqs": [
      "source": "TFM_A_IRQ",
      "name": "A_IRQ",
      "handling": "SLIH"
  "dependencies": [
    "TFM_CRYPTO",
    "TFM_INTERNAL_TRUSTED_STORAGE_SERVICE"
Update manifest list
The <TF-M base folder>/tools/tfm_manifest_list.yaml is used to collect necessary information of secure partition. The manifest tool tools/tfm_parse_manifest_list.py processes it and generates necessary files while building.
Please refer to the Manifest List for the format of manifest lists.
Reference configuration example:
  "description": "TFM Example Partition",
  "manifest": "secure_fw/partitions/example/tfm_example_partition.yaml",
  "conditional": "@TFM_PARTITION_EXAMPLE@",
  "output_path": "partitions/example",
  "version_major": 0,
  "version_minor": 1,
  "pid": 290,
  "linker_pattern": {
    "library_list": [
      "*tfm_*partition_example*"
TF-M also supports out-of-tree Secure Partition build where you can have your own manifest lists. Please refer to Out-of-tree Secure Partition build for details.
Secure Partition ID Distribution
Every Secure Partition has an identifier (ID). TF-M will generate a header file that includes definitions of the Secure Partition IDs. The header file is <TF-M build folder>generated/interface/include/psa_manifest/pid.h. Each definition uses the name attribute in the manifest as its name and the value is allocated by SPM.
The Partition ID can be set to a fixed value or omitted to be auto allocated.
#define name id-value
Table 37: PID table
Secure Partitions
PID Range
TF-M Internal Partitions
0 - 255
PSA and user Partitions
256 - 2999
TF-M test Partitions
3000 - 4999
Firmware Framework test Partitions
5000 - 5999
Reserved
6000 -
Please refer to <TF-M base folder>/tools/tfm_manifest_list.yaml, ‘’<TF-M extras repo>/partitions/*/*_manifest_list.yaml’’, <TF-M test repo>/tests_reg/test/secure_fw/tfm_test_manifest_list.yaml and <TF-M test repo>/tests_psa_arch/spe/tfm_psa_ff_test_manifest_list.yaml for the detailed PID allocations.
About where to add the definition, please refer to the chapter Update manifest list.
RoT Service ID (SID) Distribution
An RoT Service is identified by its RoT Service ID (SID). A SID is a 32-bit number that is associated with a symbolic name in the Secure Partition manifest. The bits [31:12] uniquely identify the vendor of the RoT Service. The remaining bits [11:0] can be used at the discretion of the vendor.
Here is the RoT Service ID table used in TF-M.
Table 38: SID table
Partitions
Vendor ID(20 bits)
Function ID(12 bits)
initial_attestation
0x00000
0x020-0x03F
platform
0x00000
0x040-0x05F
protected_storage
0x00000
0x060-0x06F
internal_trusted_storage
0x00000
0x070-0x07F
crypto
0x00000
0x080-0x09F
firmware_update
0x00000
0x0A0-0x0BF
tfm_secure_client
0x0000F
0x000-0x01F
tfm_ipc_client
0x0000F
0x060-0x07F
tfm_ipc_service
0x0000F
0x080-0x09F
tfm_slih_test_service
0x0000F
0x0A0-0x0AF
tfm_flih_test_service
0x0000F
0x0B0-0x0BF
tfm_ps_test_service
0x0000F
0x0C0-0x0DF
tfm_secure_client_2
0x0000F
0x0E0-0x0FF
tfm_sfn_test_service_1
0x0000F
0x100-0x11F
tfm_sfn_test_service_2
0x0000F
0x120-0x13F
tfm_attest_test_service
0x0000F
0x140-0x15F
RoT Service Stateless Handle Distribution
A Secure partition may include stateless services. They are distinguished and referenced by stateless handles. In manifest, a stateless_handle attribute is set for indexing stateless services. It must be either "auto" or a number in the range [1, 32] in current implementation and may extend. Also the connection-based attribute must be set to false for stateless services.
The indexes of stateless handles are divided into two ranges for different usages. Indexes [1, 16] are assigned to TF-M Secure Partitions. The rest indexes [17, 32] are reserved for any other Secure Partitions, for example Secure Partitions in tf-m-tests and tf-m-extras.
The following table summaries the stateless handle allocation for the TF-M Secure Partitions.
Table 39: Stateless Handle table
Partition name
Stateless Handle
TFM_SP_CRYPTO
1
TFM_SP_PS
2
TFM_SP_ITS
3
TFM_SP_INITIAL_ATTESTATION
4
TFM_SP_FWU
5
TFM_SP_PLATFORM
6
For the indexes of other Secure Partitions, please refer to their manifests or documentations.
stack_size
The stack_size is required to indicate the stack memory usage of the Secure Partition. The value of this attribute must be a decimal or hexadecimal value in bytes. It can also be a build configurable with default value defined in config_base.cmake. The value of the configuration can be overridden to fit different use cases.
heap_size
This attribute is optional. The default value is 0. It indicates the heap memory usage of the Secure Partition. The allowed values are the same as the stack_size.
mmio_regions
This attribute is a list of MMIO region objects which the Secure Partition needs access to. TF-M only supports the named_region current. Please refer to PSA FF for more details about it. The user needs to provide a name macro to indicate the variable of the memory region.
TF-M uses the below structure to indicate a peripheral memory.
struct platform_data_t {
  uint32_t periph_start;
  uint32_t periph_limit;
  int16_t periph_ppc_bank;
  int16_t periph_ppc_loc;
This structure is not expected by TF-M, it’s only that the current implementations are using. Other peripherals that need different information to create isolation need to define a different structure with the same name.
Here is an example for it:
struct platform_data_t tfm_peripheral_A;
#define TFM_PERIPHERAL_A                 (&tfm_peripheral_A)
mm_iovec
Memory-mapped iovecs (MM-IOVEC) provides direct mapping of client input and output vectors into the Secure Partition. When this attribute is set to enable, it enables Secure Partitions to use the MM-IOVEC APIs if the framework supports MM-IOVEC.
Using MM-IOVEC provides a memory and runtime optimization for larger buffers, but reduces mitigation for common security vulnerabilities. Please refer to Firmware Framework for M 1.1 Extensions for more details. Whether to use MM-IOVEC depends on the requirements of memory and runtime optimization and security.
Update the Build System
The following changes to the build system are required for the newly added secure partition.
Add a CMakeLists.txt file
Each Secure Partition must have a corresponding CMakeLists.txt, in this case, <TF-M base folder>/secure_fw/partitions/example/CMakeLists.txt, which is the compilation configuration for this Secure Partition.
Here is a reference example for CMakeLists.txt
The CMake file should include the following contents
  • Add library tfm_app_rot_partition_example and associated source files.
    add_library(tfm_app_rot_partition_example STATIC)
    target_sources(tfm_app_rot_partition_example
        PRIVATE
            tfm_example_partition.c
    The secure partition must be built as a standalone static library, and the name of the library must follow this pattern, as it affects how the linker script will lay the partition in memory:
    • tfm_psa_rot_partition* in case of a PSA RoT partition
    • tfm_app_rot_partition* in case of an Application RoT partition
  • Add source files generated by the manifest tool.
    # The intermedia file defines the partition stack.
        PRIVATE
            ${CMAKE_BINARY_DIR}/generated/example_partition/auto_generated/intermedia_tfm_example_partition.c
    # The load info file includes the static data of the partition.
    target_sources(tfm_partitions
        INTERFACE
            ${CMAKE_BINARY_DIR}/generated/example_partition/auto_generated/load_info_tfm_example_partition.c
  • Add dependency with manifest tool.
    To make sure the above generated files are up-to-date when the Secure Partition library is built, dependencies between the library and the manifest tool target should be set up.
    add_dependencies(tfm_app_rot_partition_example manifest_tool)
  • Link tfm_sprt for the PSA API interfaces.
    target_link_libraries(tfm_app_rot_partition_example
        PRIVATE
            tfm_sprt
  • Link the Secure Partition library to tfm_partitions so that it can be included in the final image.
    target_link_libraries(tfm_partitions
        INTERFACE
Finally, the build of this Secure Partition should be added to <TF-M base folder>/secure_fw/partitions/CMakeLists.txt.
add_subdirectory(example)
Update the Config System
If the Secure Partition has the build config to enable or disable it, the config option should be added to config systems.
CMake Config
The default value of the config option should be added to the <TF-M base folder>/config/config_base.cmake.
set(TFM_PARTITION_EXAMPLE  OFF  CACHE BOOL  "Enable the example partition")
Kconfig
A menuconfig should be added to <TF-M base folder>/secure_fw/partitions/example/Kconfig.
menuconfig TFM_PARTITION_EXAMPLE
    bool "Enable the Example Partition"
    default n
And add it to <TF-M base folder>/secure_fw/partitions/Kconfig
rsource ``example/Kconfig``
The Secure Partition building should be skipped if it is not enabled. This should be done by adding the following code at the beginning of its CMakeLists.txt
if (NOT TFM_PARTITION_EXAMPLE)
    return()
endif()
Implement the RoT services
To implement RoT services, the partition needs a source file which contains the implementations of the services, as well as the partition entry point. The user can create this source file under <TF-M base folder>/secure_fw/partitions/example/tfm_example_partition.c.
As an example, the RoT service with SID ROT_A will be implemented.
Entry point for IPC Model Partitions
This function must have a loop that repeatedly waits for input signals and then processes them, following the Secure Partition initialization.
#include "psa_manifest/tfm_example.h"
#include "psa/service.h"
void tfm_example_main(void)
    psa_signal_t signals = 0;
    /* Secure Partition initialization */
    example_init();
     * Continually wait for one or more of the partition's RoT Service or
     * interrupt signals to be asserted and then handle the asserted
     * signal(s).
    while (1) {
        signals = psa_wait(PSA_WAIT_ANY, PSA_BLOCK);
        if (signals & ROT_A_SIGNAL) {
            rot_A();
        } else {
            /* Should not come here */
            psa_panic();
Entry init for SFN Model Partitions
In the SFN model, the Secure Partition consists of one optional initialization function, which is declared as the entry_init symbol as mentioned in section Add manifest. After initialization, the entry_init function returns the following values:
  • Return PSA_SUCCESS if initialization succeeds.
  • Return PSA_SUCCESS if initialization is partially successful, and you want some SFNs to receive messages. RoT Services that are non-operational must respond to connection requests with PSA_ERROR_CONNECTION_REFUSED.
  • Return an error status if the initialization failed, and no SFNs within the Secure Partition must be called.
Service implementation for IPC Model
The service is implemented by the rot_A() function, which is called upon an incoming signal. This implementation is up to the user, however an example service has been included for reference. The following example sends a message “Hello World” when called.
/* Some other type of services. */
#define SOME_ROT_A_SERVICE_TYPE                (1)
static void rot_A(void)
    const int BUFFER_LEN = 32;
    psa_msg_t msg;
    int i;
    uint8_t rec_buf[BUFFER_LEN];
    uint8_t send_buf[BUFFER_LEN] = "Hello World";
    psa_get(ROT_A_SIGNAL, &msg);
    switch (msg.type) {
    case PSA_IPC_CONNECT:
    case PSA_IPC_DISCONNECT:
         * This service does not require any setup or teardown on connect
         * or disconnect, so just reply with success.
        psa_reply(msg.handle, PSA_SUCCESS);
        break;
    default:
        /* Handling services requested by psa_call. */
        if (msg.type == PSA_IPC_CALL) {
            for (i = 0; i < PSA_MAX_IOVEC; i++) {
                if (msg.in_size[i] != 0) {
                    psa_read(msg.handle, i, rec_buf, BUFFER_LEN);
                if (msg.out_size[i] != 0) {
                    psa_write(msg.handle, i, send_buf, BUFFER_LEN);
        } else if (msg.type == SOME_ROT_A_SERVICE_TYPE) {
            /* Operations for SOME_ROT_A_SERVICE_TYPE */
        } else {
            /* Invalid type for this Secure Partition. */
            return PSA_ERROR_PROGRAMMER_ERROR;
Service implementation for SFN Model
SFN model consists of a set of Secure Functions (SFN), one for each RoT Service. The connection, disconnection and request messages do not cause a Secure Partition signal to be asserted for SFN Secure Partitions. Instead, the Secure Function (SFN) for the RoT Service is invoked by the framework, with the message details provided as a parameter to the SFN. To add a secure function (SFN) to process messages for each RoT Service, each SFN will have following prototype.
psa_status_t <<name>>_sfn(const psa_msg_t *msg);
A connection-based example service has been included for reference which sends a message “Hello World” when called.
psa_status_t rot_a_sfn(const psa_msg_t *msg)
    int i;
    switch (msg->type) {
        return PSA_SUCCESS;
    default:
        if (msg->type == PSA_IPC_CALL) {
                if (msg->in_size[i] != 0) {
                    psa_read(msg->handle, i, rec_buf, BUFFER_LEN);
                if (msg.->out_size[i] != 0) {
                    psa_write(msg->handle, i, send_buf, BUFFER_LEN);
            return PSA_SUCCESS;
        } else if (msg->type == SOME_ROT_A_SERVICE_TYPE) {
        } else {
Test suites and test partitions
A regression test suite can be added to verify whether the new secure partition works as expected. Refer to Adding TF-M Regression Test Suite for the details of adding a regression test suite.
Some regression tests require a dedicated RoT service. The implementations of the RoT service for test are similar to secure partition addition. Refer to Adding partitions for regression tests to get more information.
TF-M supports out-of-tree Secure Partition build, whose source code folders are maintained outside TF-M repo. Developers can configure TFM_EXTRA_MANIFEST_LIST_FILES and TFM_EXTRA_PARTITION_PATHS in build command line to include out-of-tree Secure Partitions.
  • TFM_EXTRA_MANIFEST_LIST_FILES
    A list of the absolute path(s) of the manifest list(s) provided by out-of-tree Secure Partition(s). Use semicolons ; to separate multiple manifest lists. Wrap the multiple manifest lists with double quotes.
  • TFM_EXTRA_PARTITION_PATHS
    A list of the absolute directories of the out-of-tree Secure Partition source code folder(s). TF-M build system searches CMakeLists.txt of partitions in the source code folder(s). Use semicolons ; to separate multiple out-of-tree Secure Partition directories. Wrap the multiple directories with double quotes.
A single out-of-tree Secure Partition folder can be organized as the figure below.
secure partition folder
      ├── CMakeLists.txt
      ├── manifest_list.yaml
      ├── out_of_tree_partition_manifest.yaml
      └── source code
In the example above, TFM_EXTRA_MANIFEST_LIST_FILES and TFM_EXTRA_PARTITION_PATHS in the build command can be configured as listed below.
-DTFM_EXTRA_MANIFEST_LIST_FILES=<Absolute-path-sp-folder/manifest_list.yaml>
-DTFM_EXTRA_PARTITION_PATHS=<Absolute-path-sp-folder>
Multiple out-of-tree Secure Partitions can be organized in diverse structures. For example, multiple Secure Partitions can be maintained under the same directory as shown below.
top-level folder
      ├── Partition 1
      │       ├── CMakeLists.txt
      │       ├── partition_1_manifest.yaml
      │       └── source code
      ├── Partition 2
      ├── Partition 3
      └── Root CMakeLists.txt
In the example above, a root CMakeLists.txt includes all the partitions’ CMakLists.txt, for example via add_subdirectory(). The manifest_list.yaml lists all partitions’ manifest files. TFM_EXTRA_MANIFEST_LIST_FILES and TFM_EXTRA_PARTITION_PATHS in build command line can be configured as listed below.
-DTFM_EXTRA_MANIFEST_LIST_FILES=<Absolute-path-top-level-folder/manifest_list.yaml>
-DTFM_EXTRA_PARTITION_PATHS=<Absolute-path-top-level-folder>
Alternatively, out-of-tree Secure Partitions can be separated in different folders.
partition 1 folder                    partition 2 folder
    ├── CMakeLists.txt                    ├── CMakeLists.txt
    ├── manifest_list.yaml                ├── manifest_list.yaml
    ├── partition_1_manifest.yaml         ├── partition_2_manifest.yaml
    └── source code                       └── source code
In the example above, each Secure Partition manages its own manifest files and CMakeLists.txt. TFM_EXTRA_MANIFEST_LIST_FILES and TFM_EXTRA_PARTITION_PATHS in build command line can be configured as listed below. Please note those input shall be wrapped with double quotes.
-DTFM_EXTRA_MANIFEST_LIST_FILES="<Absolute-path-part-1-folder/manifest_list.yaml>;<Absolute-path-part-2-folder/manifest_list.yaml>"
-DTFM_EXTRA_PARTITION_PATHS="<Absolute-path-part-1-folder>;<Absolute-path-part-2-folder>"
Manifest list paths in TFM_EXTRA_MANIFEST_LIST_FILES do NOT have to be one-to-one mapping to Secure Partition directories in TFM_EXTRA_PARTITION_PATHS. The orders don’t matter either.
TFM_EXTRA_MANIFEST_LIST_FILES and TFM_EXTRA_PARTITION_PATHS can be configured in multiple extra sources. It is recommended to use CMake list APPEND method to avoid unexpected override.
Further Notes
  • In the IPC model, Use PSA FF proposed memory accessing mechanism. SPM provides APIs and checking between isolation boundaries, a free accessing of memory can cause program panic.
  • In the IPC model, the memory checking inside partition runtime is unnecessary. SPM handles the checking while memory accessing APIs are called.
  • In the IPC model, the client ID had been included in the message structure and secure partition can get it when calling psa_get() function. The secure partition does not need to call tfm_core_get_caller_client_id() to get the caller client ID anymore.
  • In the IPC model, SPM will check the security policy and partition dependence between client and service. So the service does not need to validate the secure caller anymore.
SPDX-FileCopyrightText: Copyright The TrustedFirmware-M Contributor
