Advisory TFMV-5
Public Disclosure Date |
Feb 11, 2022 |
From 3e7129f552c4cfd2973b9c17f3565df1ba45b334 to 921d0eaa85595e9b992de866b9da8b0d7dfe08eb |
IPC model with Firmware Update partition enabled |
In IPC model, the caller of |
Mark Horvath, Staff Software Engineer from Arm Ltd. |
In Firmware Update partition, the psa_fwu_write() service is declared as:
* \brief Writes an image to its staging area.
* Writes the image data 'block' with length 'block_size' to its staging area.
* \param[in] image_id The identifier of the image
* \param[in] block_offset The offset of the block being passed into block,
* in bytes
* \param[in] block A buffer containing a block of image data. This
* might be a complete image or a subset.
* \param[in] block_size Size of block. The size must not be greater than
* PSA_FWU_MAX_BLOCK_SIZE.
psa_status_t psa_fwu_write(psa_image_id_t image_id,
size_t block_offset,
const void *block,
size_t block_size);
In IPC model, this service calls the tfm_fwu_write_ipc() API to write
the input data into the device. In this API, the block_size bytes
input data (in block argument) is read into a 1024 bytes local
buffer via the psa_read() API. If the input argument block_size
is greater than 1024, then the memory space starting from the address
of the local buffer with block_size bytes would be overwritten by the input
data in block argument.
In IPC model, the caller of psa_fwu_write() from SPE or NSPE can overwrite
the memory space in RAM. The overwritten memory space ranges from the address
of the local buffer which locates at the stack of Firmware Update partition to
the end of the RAM. The overwritten memory may include the data of SPM and
device drivers, as well as part of the stack of Firmware Update partition.
Add check against the input buffer length in the tfm_fwu_write_ipc() API
before reading the input data into the local buffer. See commit
78f75304269baf4fc349f1a2b687675e71d2955e.
Copyright (c) 2022, Arm Limited. All rights reserved.
