Advisory TFMV-9
FWU does not check the length of the TLV’s payload
CVE-2025-53022
Public Disclosure Date
Jul 21, 2025
All version from TF-M v1.3.0 up to TF-M v2.2.0 inclusive
Configurations
Any with Firmware Update (FWU) partition enabled
A Type-Length-Value (TLV) payload can be larger than the image dependency resulting in out-of-bounds write
6d074b68d3eb3e34038c1b074a68d92a8fea3f82
Credits
Bartek Piekarski Distinguished Engineer, Product Security, Arm Ltd.
In Firmware Update partition, the fwu_bootloader_install_image() function checks the authenticity and integrity of the image candidates. For each image candidate, its dependencies are loaded and when criteria are met, the candidate image is staged. During the dependencies check, the length of the image dependency fetched from the TLV is not verified, and this could lead to overflow in read and write from memory in subsequent steps.
An incorrect and unchecked TLV data can result in accessing the reading and writing memory for the candidate images that goes beyond the bounds, possibly causing in a redirection of program execution.
Add a length check in the fwu_bootloader_install_image() immediately after the next TLV is found by bootutil_tlv_iter_next(), during the dependencies fetch. See commit 6d074b68d3eb3e34038c1b074a68d92a8fea3f82.
