FF-M Isolation
This document analyzes the isolation rules of implementing Firmware Framework for M 1.1 (FF-M 1.1) [2] isolation and introduces the reference implementation in TF-M, which complies with the rules by operating the hardware and software resources.
Reference the document Glossary for terms and abbreviations.
This chapter describes the definitions from Firmware Framework for M (FF-M) [1] and analyzes the possible implementation keypoints.
Isolation Levels
There are 3 isolation levels (1-3) defined in FF-M, the greater level number has more isolation boundaries.
The definition for Isolation Level 1:
L1.1 NPSE needs protection from nobody.
L1.2 SPE needs protection from NSPE.
The definition for Isolation Level 2:
L2.1 NPSE needs protection from nobody.
L2.2 Application Root of Trust (ARoT) needs protection from NSPE.
L2.3 PSA Root of Trust (PRoT) needs protection from NSPE and ARoT.
The definition for Isolation Level 3:
L3.1 NPSE needs protection from nobody.
L3.2 Secure Partition needs protection from NSPE and other Secure Partitions.
L3.3 PSA Root of Trust (RoT) domain needs protection from NSPE and all Secure Partitions.
Important
A Secure Partition RoT Service is a Root of Trust Service implemented within a Secure Partition. An Application RoT Service must be implemented as a Secure Partition RoT Service. But it is implementation-defined whether a PSA RoT Service is a Secure Partition RoT Service.
Here listed several possible PSA RoT Service implementation mechanisms:
Implement PSA RoT Services in Secure Partitions with respective boundaries.
Implement PSA RoT Services in Secure Partitions, but no boundaries between these Secure Partitions as they are in the PSA RoT Domain.
Implement PSA RoT Services in a customized way instead of Secure Partitions, an internal library of PSA RoT domain e.g.
TF-M chooses the 2nd option to balance performance and complexity.
Isolation Rules
The essence of isolation is to protect the assets of one protection domain from being accessed from other domains. The isolation levels define where the isolation boundaries should be placed, the isolation rules define the strength of the isolation the boundaries should offer.
Refer to chapter Memory Assets in FF-M [1] to know asset class items. Assets are represented by memory addresses in the system memory map, which makes assets named Memory Assets. The often-seen asset items are ROM, RAM, and memory-mapped peripherals.
Memory Asset Class
There are 3 memory asset classes defined in FF-M:
Code
Constant data
Private data
There are 7 isolation rules for protecting assets described in chapter 3.1
of FF-M 1.0 [1] and chapters 8.4 to 8.5 of FF-M 1.1 [2]. The following
is a summary of the rules:
I1. (Changed in FF-M 1.1) Private data is not executable.
I2. Only private data is writable.
I3. If domain A needs protection from domain B, then Private data in domain A cannot be accessed by domain B.
I4. (Optional, changed in FF-M 1.1) If domain A needs protection from domain B, then Code and Constant data in domain A, which is not part of a shared library, is not readable or executable by domain B.
I5. (Optional, changed in FF-M 1.1) Code in a domain, which is not part of a shared library, is not executable by any other domain.
I6. (Optional) All assets in a domain are private to that domain and cannot be accessed by any other domain, with the following exception: The domain containing the SPM can only access Private data and Constant data assets of other domains when required to implement the PSA Firmware Framework API.
I7. (Optional, added in FF-M 1.1) Constant data is not executable.
The first 3 rules from
I1toI3define the mandatory rules to comply with the PSA security model, whileI4toI7are optional rules to enhance the isolation boundaries.Important
There is a table in chapter
3.1.2of FF-M 1.0 [1] underI1that lists the asset types and allowed access method. Preventing executable access to constant data costs more hardware resources, so there is an optional rule I7 created in FF-M 1.1 [2] to aid implementations with constrained hardware resources.
Hardware Infrastructure
To implement a secure system, the hardware security framework (e.g. TrustZone or multiple-core) and their auxiliary components (e.g. SAU) are required to ensure the isolation between SPE and NSPE, as described in Trusted Base System Architecture for M (TBSA-M) [3].
Important
The interface between secure and non-secure states needs to be fully enumerated and audited to prove the integrity of the secure state isolation.
Besides this SPE and NSPE isolation mechanism, the following analyzes the implementation rules to find out the hardware requirements for isolation inside SPE domains:
I1, I2 and I7: The assets can be categorized into 3 Memory Asset Class, each type has the specific access rules.
I3: The private data access from the prevented domain needs to be blocked.
I4: All the assets access from the prevented domain needs to be blocked.
I5: Code execution from all other domains (even the domain not prevented from) needs to be blocked.
I6: All the assets access from all other domains (includes non-prevented domain) needs to be blocked, but, SPM is an exception, which can access the private data and constant data of the current domain.
The above items list the requirements for memory access, here are two more points:
If the memory device or the peripheral are shared between multiple hosts (such as multiple CPU or DMA, etc.), specific hardware protection units need to be available for validating accesses to that device or peripheral.
The MMIO range for Secure Partitions is not allowed to be overlapped, which means each partition should have exclusive memory-mapped region if they require a peripheral device. The memory-mapped region is regarded as the private data so access to this area needs to be validated.
Reference Implementation
This chapter describes the isolation implementation inside SPE by using the Armv8-M architecture component - Memory Protection Unit (MPU). The MPU can isolate CPU execution and data access.
Previous version M-profile architecture MPU setting is similar in concept but the difference in practical register formats, which is not described in this document.
The MPU protects memory assets by regions. Each region represents a memory range with specific access attributes.
The maximum numbers of MPU regions are platform-specific.
The SPM is running under the privileged mode for handling access from services. The MPU region for SPM needs to be available all the time since SPM controls the MPU setting while scheduling.
Since partitions are scheduled by SPM, the MPU regions corresponding to the partitions can be configured dynamically while scheduling. Since there is only one running at a time and all others are deactivated, the SPM needs to set up necessary regions for each asset type in one partition only.
There is reusable code like the C-Runtime and RoT Service API which are same across different partitions. TF-M creates a Secure Partition Runtime Library (SPRTL) as a specific library shared by the Secure Partition. Please refer to Secure Partition Runtime Library for more detail.
Enable SPRTL makes it hard to comply with the rules I4, I5 and I6, duplicating the library code can be one solution but it is not “shared” library anymore.
As mentioned in the last chapter, MMIO needs extra MPU regions as private data.
MPU Region Access Permission
The following content describes the memory access permission to represent the corresponding asset classes.
These access permissions are available on Armv8-M MPU:
Privileged Read-Only (RO)
All RO
Privileged Read-Write (RW)
All RW
Execute Never (XN)
And one more Armv8.1-M access permission:
Privileged Execute Never (PXN)
The available regions type list:
Type |
Attributes |
Privilege Level |
Asset |
P_RO |
RO |
Privileged |
PRoT Code |
P_ROXN |
RO + XN |
Privileged |
PRoT Constant Data |
P_RWXN |
RW + XN |
Privileged |
PRoT Private Data/Peripheral |
A_RO |
RO |
Any privilege |
Partition/SPRTL Code |
A_ROXN |
RO + XN |
Any privilege |
Partition/SPRTL Constant Data |
A_RWXN |
RW + XN |
Any privilege |
Partition/SPRTL Private Data/Peripheral |
A_ROPXN |
RO + PXN |
Any privilege |
Armv8.1-M Partition Code |
Example Image Layout
The secure firmware image contains components such as partitions, SPM and the shared code and data. Each component may have different class assets. There would be advantages if placing the assets from all components with the same access attributes into one same region:
The data relocating or clearing when booting can be done in one step instead of breaking into fragments.
Assets with statically assigned access attribute can share the same MPU region which saves regions.
Take the TF-M existing implementation image layout as an example:
Level 1 Level 2 Level 3
Boundaries Boundaries Boundaries
| | | PRoT SPM Code |
| | PRoT +------------------------------------+
| | Code | PRoT Service Code |
| Code +----------+------------------------------------+
| (ROM) | | Partition 1 Code |
| | ARoT | Partition N Code |
| | Code +------------------------------------+
| | | SPRTL Code |
Check [4] for more details between Code and Constant Data.
| | PRoT | PRoT SPM Constant Data |
| | Constant +------------------------------------+
| | Data | PRoT Service Constant Data |
| Constant +----------+------------------------------------+
| Data | ARoT | Partition 1 Constant Data |
| (ROM) | Constant +------------------------------------+
| | Data | Partition N Constant Data |
| | PRoT | PRoT SPM Private Data |
| | Private +------------------------------------+
| | Data | PRoT Service Private Data |
| Private +----------+------------------------------------+
| Data | | Partition 1 Private Data |
| (RAM) | ARoT +------------------------------------+
| | Private | Partition N Private Data |
| | Data +------------------------------------+
| | | SPRTL Private Data |
Multiple binaries image implementation could also reference this layout if its hardware protection unit can cover the exact boundaries mentioned above.
Private data includes both initialized and zero-initialized (ZI) sections. Check chapter
3.1.1of FF-M [1] for the details.This diagram shows the boundaries but not orders. The order of regions inside one upper region can be adjusted freely.
As described in the
importantof Memory Asset Class, the setting between Code and Constant Data can be skipped if the executable access method is not applied to constant data. In this case, the groups of Code and Constant Data can be combined or even mixed – but the boundary between PRoT and ARoT are still required under level higher than 1.
Example Region Numbers under Isolation Level 3
The following table lists the required regions to comply with the rules for implementing isolation level 3. The level 1 and level 2 can be exported by simplifying the items in level 3 table.
Important
The table described below is trying to be shared between all supported platforms in Trusted Firmware-M. It is obvious that some platforms have special characteristics. In that case, the specific layout table for a particular platform can be totally redesigned but need to fulfil the isolation level requirements.
Only the running partition’s assets are covered since the inactive partitions do not need regions.
Xindicates the existence of this region can’t comply with the rule.An
ATTR + nrepresent extranregions are necessary.The table assumes each rule is in addition to the rules in previous columns (but the FF-M permits any combination of optional rules).
The following table lists the required regions to comply with the rules:
Region Purpose |
I1 I2 I3 I7 |
I4 |
I5 |
I6 |
PRoT SPM Code |
A_RO |
P_RO |
P_RO |
P_RO |
PRoT Service Code |
A_ROPXN |
Active Partition Code |
A_RO |
A_ROPXN |
SPRTL Code |
A_RO |
A_RO |
PRoT SPM RO |
A_ROXN |
P_ROXN |
P_ROXN |
P_ROXN |
PRoT Service RO |
A_ROXN |
Active Partition RO |
A_ROXN |
A_ROXN |
SPRTL RO |
A_ROXN |
A_ROXN |
PRoT SPM RW |
P_RWXN |
P_RWXN |
P_RWXN |
P_RWXN |
PRoT Service RW |
A_RWXN |
Active Partition RW |
A_RWXN |
A_RWXN |
A_RWXN |
SPRTL RW [5] |
A_RWXN + 1 |
A_RWXN + 1 |
A_RWXN + 1 |
Partition Periph |
A_RWXN + n |
A_RWXN + n |
A_RWXN + n |
A_RWXN + n |
Total Numbers |
[1] |
[2] |
[3] |
[4] |
Total number = A_RO + A_ROXN + P_RWXN + (2 + n)A_RWXN =
5 + n, wherenis the maximum number of peripherals needed by one partition.Total number = [1] + P_RO + A_RO + P_ROXN + A_ROXN =
9 + n(or6 + nwithout SPRTL).Total number = [2] =
9 + n, and Armv8.1-M PXN is required.Total number = P_RO + A_ROPXN + P_ROXN + A_ROXN + P_RWXN + (1 + n)A_RWXN =
6 + n, but SPRTL cannot be used, and Armv8.1-M PXN is required. To comply with this rule, the PSA RoT Services need to be implemented as Secure Partitions.This data belongs to SPRTL RW but it is set as Read-Only and only SPM can update this region with the active partition’s metadata for implementing functions with owner SP’s context, such as heap functions. This region can be skipped if there is no metadata required (such as no heap functionalities required).
The memory-mapped regions for peripherals have different memory access attributes in general, they are standalone regions in the MPU even though their attributes covers ‘A_RWXN’.
TF-M provides the reference linker scripts tfm_isolation_s.sct.template,
tfm_isolation_s.ld.template, and tfm_isolation_s.icf.template for the
Armclang, GCC, and IAR compilers in the platform/ext/common directory. These
linker scripts arrange the SPE’s memory by attribute to aid the implementation
of the isolation rules.
The reference isolation HAL for Armv8-M and Armv8.1-M platforms in
platform/ext/common/tfm_hal_isolation_v8m.c uses the memory position tags
defined by the linker scripts to set up the MPU region base and limit addresses.
It implements isolation rules I1, I2, I3 and I7 for isolation levels 1 to 3. It
partially implements rule I4 by statically partitioning code into privileged and
unprivileged read-only regions but collecting all constant data into a single
unprivileged, read-only, execute-never region, which provides a good level
of protection against ROP attacks by limiting the amount of executable memory.
On Armv8.1-M targets, it statically configures all Application RoT Partition
code as PXN, which is sufficient to satisfy rule I5 in isolation level 2, but
not in isolation level 3, where it would require dynamically mapping only the
active partition’s code region.
TF-M platforms may replace the reference linker scripts and/or isolation HAL with a customized implementation, but it must meet at least isolation rules I1, I2 and I3 to comply with the PSA security model.
Default access rules
Hardware protection components MAY have the capability to collect regions not explicitly configured in static or runtime settings, and then apply default access rules to these regions. Furthermore, one default rule can be applied to multiple non-contiguous regions which makes them share a common boundary. This operation sets up a standalone ‘region’ the same as other explicitly configured regions. And it doesn’t affect the analysis summary above - just be aware that some regions listed in the table MAY not be explicitly configured.
Take the MPU as an example, MPU can assign a default privileged access attribute to the regions (e.g. SPM and PRoT regions) not explicitly configured. This feature can reduce required MPU regions and ease the programming because regions can be put non-address-contiguous and skip the explicit configuration.
Important
When this default access rules mechanism is applied, the implicitly configured regions must be reviewed to ensure the isolation boundaries are set correctly.
Interfaces
The isolation implementation is based on the HAL framework. The SPM relies on the HAL API to perform the necessary isolation related operations.
The requirement the software need to do are these:
Create enough isolation protection at the early stage of system booting, just need to focus on the SPM domain.
Create an isolation domain between secure and non-secure before the jump to the non-secure world.
Create an isolation domain for each Secure Partition after the Secure Partition is loaded and before jumping to its entry point. The isolation domain should cover all the assets of the Secure Partition, include all its memory, interrupts, and peripherals.
Switch isolation domains when scheduling different Secure Partitions.
It is also a requirement that the platform needs to help to check if the caller of the PSA APIs is permitted to access some memory ranges.
The design document TF-M Hardware Abstraction Layer gives a detail design, include the platform initialization, isolation interfaces. Please refer to it for more detail.
Copyright (c) 2020-2024, Arm Limited. All rights reserved.
