Source Structure
TF-M is designed to provide a user-friendly source structure to ease integration and service development. This document introduces the source structure and its design intention of TF-M. Additionally, the folders below are important for TF-M integration and described in a separate documents:
/ (TF-M root)
This table describes the structure under the root folder with part of possible folders.
Folder name |
Description |
bl1 |
The 1st stage immutable bootloader |
bl2 |
MCUBoot based 2nd stage bootloader |
cmake |
Cmake files of the build system |
config |
Configuration system files |
docs |
The documentation |
interface |
RoT service API for client calls |
lib |
The 3rd party libraries |
Platform intermedia files |
The secure firmware |
tools |
Tools in scripts for building |
platform
The platform folder contains SW ports of all supported platforms and the files necessary for adding a new platform. Please refer to platform folder document for more information.
Folder name |
Description |
include |
HAL and platform public headers |
ext |
Platform ports and related files |
platform/ext
This folder can include imported files licensed differently from TF-M’s BSD-3 license. More details are in the dedicated document Details for the platform/ext folder.
Folder name |
Description |
accelerator |
Supported Crypto HW accelerators |
cmsis |
A copy of essential CMSIS headers |
common |
Common HAL implementation |
driver |
Driver headers for porting |
target/<vendor> |
Vendor specific folders with ported platforms |
Each vendor is assigned one folder for usage under target/. A vendor contributes platform’s ports and manages the structure inside it.
secure_fw
This folder contains components needed by secure firmware and the exported interfaces for application, service development and HAL integration.
Folder name |
Description |
include |
Public headers of secure_fw |
partitions |
Default services and SPRTL |
spm |
PSA FF-M SPM implementation |
shared |
Sources shared out of SPRTL |
The shared sources can be referenced by the building system out of SPRTL. Generally, they are runtime and PSA APIs.
secure_fw/include
This folder holds public headers for external references by clients, services and platforms. Avoid putting private headers, not referenced by other modules in this include folder.
secure_fw/partitions
This folder contains default services implemented as partitions and runtime utilities used and provided by TF-M.
Folder name |
Description |
lib/runtime |
The SPRTL sources and intermedia files |
<partition_x> |
Sources of partition_x |
<partition_x>/include |
RoT Service API headers of partition_x |
<partition_y> |
Sources of partition_y |
<partition_y>/include |
RoT Service API headers of partition_y |
Here partition_x and partition_y are examples of RoT services without detailed structure of them.
secure_fw/spm
The SPM is the core component to provide a mechanism for providing secure services complied with PSA FF-M.
Folder name |
Description |
include |
SPM public headers. |
core |
SPM base functionalities |
*ext |
Extended SPM functionalities |
Copyright (c) 2020-2023, Arm Limited. All rights reserved.
