Platform Provisioning
TF-M stores any data that should be provisioned at the factory in OTP memory. The default is that this OTP memory is actually implemented using on-chip flash, the same that is used to implement the ITS service.
If the lifecycle state is in the TFM_SLC_ASSEMBLY_AND_TEST [1] state (which
is the default for non-provisioned boards), then TF-M will attempt to provision
the:
- HUK
instead of booting. It will read the data from the
assembly_and_test_prov_data struct, and will then provision it to OTP. The
lifecycle state will then transition to TFM_SLC_PSA_ROT_PROVISIONING [1].
If the lifecycle state is in the TFM_SLC_PSA_ROT_PROVISIONING [1] state,
then TF-M will attempt to provision the:
IAK
boot seed
implementation id
certification reference
bl2 ROTPKs (of which there are up to 4)
entropy seed
Once all of these have been loaded from the psa_rot_prov_data struct and
provisioned to OTP, the LCS will transition to TFM_SLC_SECURED [1]. Note
that this provisioning step will be run immediately after the
TFM_SLC_ASSEMBLY_AND_TEST [1] provisioning stage if the lifecycle
transition completed successfully.
Provisioning development hardware
If TFM_DUMMY_PROVISIONING is enabled in the cmake config (as it is by
default), a set of dummy keys / data will be provisioned. The dummy IAK matches
the IAK tested by the TF-M tests, and the dummy bl2 ROTPKs match the dummy bl2
keys used by default. TFM_DUMMY_PROVISIONING _MUST_ not be used in
production hardware, as the keys are insecure.
Provisioning production hardware
For provisioning of real hardware, firstly TFM_DUMMY_PROVISIONING must be
disabled. Then it is required to inject the keys into RAM so they populate the
assembly_and_test_prov_data and psa_rot_prov_data structs, at the
beginning of the TF-M boot. These structs each require a magic value to be set
to be accepted by the provisioning code, which is detailed in
platform/ext/common/provisioning.c. Two suggestions for how to do this are:
Attach a debugger, and inject the values into RAM.
Flash an image that contains the required data. Care must be taken with this approach that the keys are not left in RAM after provisioning, so a different image (without provisioning data embedded) must be flashed afterwards, without erasing the OTP flash area.
Provisioning on CryptoCell-312 enabled platforms
On boards that have a CC312 accelerator, and that have the default flash-backed
OTP disabled by setting PLATFORM_DEFAULT_OTP=OFF in cmake, the CC312 OTP
will be used as a backing for the OTP HAL.
Due to the CC312 requiring a power-cycle to transition LCS, you will be prompted to manually power-cycle the board between provisioning stages.
Boards with real OTP memory cannot be reprovisioned - care should be taken that the data being provisioned is the desired data.
Platform-specific OTP backing
If a platform has a medium that is suitable for storing data with OTP semantics
(Where a bit cannot transition from a 1 to a 0), such as physical OTP memory,
then it can provide a backing for the OTP HAL by implementing the methods
described in tfm_plat_otp.h.
Copyright (c) 2020-2022, Arm Limited. All rights reserved.
