Platform Service Integration Guide
TF-M Platform service is a trusted service which allows secure partitions and non-secure applications to interact with some platform-specific components. There are a number of features which requires some interaction with platform-specific components which are at the same time essential for the security of the system. Therefore, those components need to be handled by a secure partition which is part of the trusted compute base.
These platform-specific components include system reset, power management, Debug, GPIO, etc.
TF-M Platform interfaces
The TF-M interfaces for the Platform service are located in
interface/include/.
The TF-M Platform service source files are located in
secure_fw/partitions/platform.
The Platform service interfaces and types are defined and documented in
interface/include/tfm_platform_api.h
platform_sp.h/c: These files define and implement functionalities related to the platform servicetfm_platform_api.c: This file implementstfm_platform_api.hfunctions to be called from the secure partitions. This is the entry point when the secure partitions request an action to the Platform service (e.g system reset).
Platform HAL
The Platform Service relies on a platform-specific implementation to perform some functionalities. Mandatory functionality (e.g. system reset) that are required to be implemented for a platform to be supported by TF-M have their dedicated HAL API functions. Additional platform-specific services can be provided using the IOCTL function call.
For API specification, please check: platform/include/tfm_platform_system.h
An implementation is provided in all the supported platforms. Please, check
platform/ext/target/<SPECIFIC_TARGET_FOLDER>/services/src/tfm_platform_system.c
for examples.
The API must be implemented by the system integrators for their targets.
IOCTL
A single entry point to platform-specific code across the HAL is provided by the IOCTL service and HAL function:
enum tfm_platform_err_t tfm_platform_hal_ioctl(tfm_platform_ioctl_req_t request,
psa_invec *in_vec,
psa_outvec *out_vec);
A request type is provided by the client, with additional parameters contained
in the optional in_vec parameter. An optional output buffer can be passed to
the service in out_vec.
An IOCTL request type not supported on a particular platform should return
TFM_PLATFORM_ERR_NOT_SUPPORTED
Non-Volatile counters
The Platform Service provides an abstracted service for exposing the NV counters to secure partitions or non-secure callers. The following operations are supported:
Increment a counter.
Read a counter value to a preallocated buffer.
tfm_platform_nv_counter_increment(uint32_t counter_id);
tfm_platform_nv_counter_read(uint32_t counter_id,
uint32_t size, uint8_t *val);
The range of counters id is defined in :
platform/include/tfm_plat_nv_counters.h
For Level 2,3 isolation implementations, secure partitions in the
Application Root of Trust, should have TFM_PLATFORM_SERVICE set as a
dependency for access to the NV counter API.
Current Service Limitations
system reset - The system reset functionality is only supported in isolation level 1. Currently the mechanism by which PSA-RoT services should run in privileged mode in level 3 is not in place due to an ongoing work in TF-M Core. So, the
NVIC_SystemResetcall performed by the service is expected to generate a memory fault when it tries to access theSCB->AIRCRregister in level 3 isolation.
Copyright (c) 2018-2022, Arm Limited. All rights reserved.
