TF-M builtin keys
- Author:
Raef Coles
When TF-M is integrated on a platform, the platform itself can provide several keys for usage which are bound to the device instead of being owned by a specific secure partition. When those keys are readable by the secure processing environment, the platform must provide a function to load these keys in the HAL layer, either loading them from OTP or another platform specific location or subsystem. These keys are henceforth referred to as “builtin keys”, and might include (but are not limited to) the following:
The Hardware Unique Key (HUK)
The Initial Attestation Key (IAK)
The tfm_builtin_key_loader component implements a mechanism to discover
those keys and make them available to the PSA Crypto APIs for usage. Note that
if a key is stored in a subsystem which can’t be read by the secure
processing environment, a full opaque driver [1] must be used to be able to use
those keys through the PSA Crypto APIs. This document focuses only on the case
where the keys can be read by the SPE (i.e. running TF-M), so the driver applies
only on those cases, which can be considered as “_transparent_ builin keys”.
In TF-M’s legacy solution, the IAK is loaded by the attestation service as a
volatile key, which requires some key-loading logic to be implemented by that
partition. The HUK is not loaded in the crypto service, and is instead used by
an implementation of a TF-M specific KDF algorithm which then loads the key and
invokes TF-PSA-Crypto directly. Both solutions are far from ideal as they
require an effort to load (and duplicate) the keys per each user, or require a
dedicated code in TF-M that directly interacts with the HAL layer and invokes
functions from the crypto library bypassing the PSA Crypto interface. The aim of
the tfm_builtin_key_loader driver is to provide a uniform interface to use
the builtin keys available in a platform.
Implementing a driver to deal with builtin keys allows to expand the legacy solution for dealing with this type of keys in several ways. For example, it avoids the need for partitions to implement dedicated mechanisms for probing the HAL layer for builtin keys and load them as volatile. It removes the need to have implementation specific call flows for deriving keys from the HUK (as that requirement now is fulfilled by the driver itself transparently). It allows uniform access to the keys also from the NS world (in any case, subject to the policy dictated by the platform). Correctly abstracts away details of the key handling mechanism from TF-M partitions into the PSA Crypto core key management subsystem.
PSA builtin keys
The PSA Cryptographic API provides a mechanism for accessing keys that are stored in platform-specific locations (often hardware accelerators or OTP). A builtin key is assigned a specific key_id, i.e. a handle, which is hardcoded at build time and must be selected in the range [MBEDTLS_PSA_KEY_ID_BUILTIN_MIN, MBEDLTS_PSA_KEY_ID_BUILTIN_MAX]. A user of the PSA Crypto API can reference those keys directly by using these handles. It is up to the platform to specify policy restrictions for specific users of the keys, e.g. an NS entity, or a secure partition. The PSA Crypto core will then check those policies to grant or deny access to the builtin key for that user.
PSA cryptoprocessor driver API
The PSA specification allows the PSA Crypto APIs to defer their operation to an
accelerator driver, through a mechanism described in the PSA cryptoprocessor
driver interface specification [1]. This specification defines the concept of
PSA Crypto core, i.e. “An implementation of the PSA Cryptography API is
composed of a core and zero or more drivers”. The PSA specification also has
the concept of storage locations for keys, through the type
psa_key_location_t, which is used to access keys that don’t have local
storage [2]. This is leveraged mainly by opaque drivers mainly that use keys
for which the key material is not readable by the PSA crypto core layer.
TF-M defines a software driver called tfm_builtin_key_loader that provides
no acceleration but just defines a dedicated key location defined through the
TFM_BUILTIN_KEY_LOADER_KEY_LOCATION define. By resorting to the entry points
provided by this driver, the PSA Crypto core slot management subsystem can
access keys stored in the underlying platform, validate key usage policies and
allow PSA Crypto APIs to uniformly access builtin keys using the same call flows
used with traditional local-storage keys.
This is implemented by hooking the entry points defined by the driver into the
library/psa_crypto_driver_wrappers.c file provided by the PSA Crypto core.
This is currently done manually but eventually could be just autogenerated by
parsing a description of the driver entry points in the JSON format. These entry
points are:
tfm_builtin_key_loader_init
tfm_builtin_key_loader_get_key_buffer_size
tfm_builtin_key_loader_get_builtin_key
The call flow for the entry points from the driver wrapper layer is as follows:
During the driver initialisation phase started by the PSA Crypto Core init, the
tfm_builtin_key_loader_initfunction is called to probe the platform HAL and retrieve the builtin keys. Those keys are described by the types defined in the HAL layer interface headertfm_plat_crypto_keys.h. In particular global tables describing key properties and user policies must be implemented by each platform and are retrieved by the two accessor functionstfm_plat_builtin_key_get_desc_table_ptr()andtfm_plat_builtin_key_get_policy_table_ptr(). The keys are loaded from the platform in secure RAM in the TF-M Crypto partition with associated metadata. It’s worth to note that the keys are loaded through callback functions which the platform lists in the key descriptor table.Once the TF-M Crypto service is initialised, at runtime it might receive a request through an API call to use one of the builtin key IDs. Those IDs are described in the
tfm_builtin_key_ids.hheader. Platforms can override the default values providing their own header.When the PSA Crypto core in the
psa_get_and_lock_key_slot()function checks that thekey_idbeing requested is in the builtin range region, it probes the platform through the functionmbedtls_psa_platform_get_builtin_keywhich must be implemented by the TF-M Crypto service library abstraction layer. This function just checks the key descriptor table from the HAL to understand if suchkey_idis available in the platform and what are the correspondingslotandlifetimevalues associated to it. The lifetime contains the location of the key, which determines which driver is responsible for dealing with it (for thetfm_builtin_key_loaderdriver, that isTFM_BUILTIN_KEY_LOADER_KEY_LOCATION), while theslotvalue maps the key to the slot in the driver internal storage.At this point, the PSA Crypto core knows that the key exists and is bound to the location associated to the driver. By calling into the driver wrappers layer is then able to retrieve the key attributes stored in the platform for that key ID, and the size required to allocate in its internal slot management system in order to load the key material in the core. This is done by calling
tfm_builtin_key_loader_get_builtin_keyjust with a valid key attributes pointer (and nothing else), to retrieve the attributes. Once the attributes are available, the required size is retrieved through the driver wrapper by callingtfm_builtin_key_loader_get_key_buffer_size.At this stage, the slot management subsystem calls again into the driver wrapper layer through
tfm_builtin_key_loader_get_builtin_keywith a valid buffer to hold the key material returned by thetfm_builtin_key_loaderdriver. When loading the key, the user requiring that key_id is validated by the driver code against the policies defined by the platform. If the policies match, the builtin key material and metadata is loaded and is used like a transparent key available to the PSA Crypto core slot management subsystem.
Technical details
Builtin key IDs and overriding
TF-M builtin key IDs are defined in
interface/include/crypto_keys/tfm_builtin_key_ids.h through the enum
tfm_key_id_builtin_t. They are allocated inside the range that PSA
specifies for the builtin keys, i.e. between MBEDTLS_PSA_KEY_ID_BUILTIN_MIN
and MBEDLTS_PSA_KEY_ID_BUILTIN_MAX. A platform can specify extra builtin key
IDs by setting the PLATFORM_DEFAULT_CRYPTO_KEYS variable to OFF,
creating the header tfm_builtin_key_ids.h, and specifying new keys and IDs.
Builtin key access control
A builtin key is accessible by all callers since the key_id associated to it
is public information. Access to the keys must be mediated, which is done by
matching the user requesting the key_id against the policies available for
that user on that particular key in the policy table. If no policies are
specified for a specific combination of user and key_id, the usage flags in
the key attributes will be all set to zeros, meaning the key will be unusable
for any operation for that particular user.
Multi-partition key derivation
The HUK is used for key derivation by any secure partition or NS caller that requires keys that are bound to a particular context. For example, Protected Storage derives keys uniquely for each user of the service which are used to encrypt user files. In order to provide HUK derivation to every secure partition / NS caller, it must be ensured that no service that utilises HUK derivation can derive the same key as another service (simply by using the same inputs for the KDF APIs, i.e. accessing the same base key for derivation).
This is accomplished by deriving a further “platform key” for each builtin key
that has PSA_KEY_USAGE_DERIVE set in its attributes. These platform keys
are derived from the builtin key, using the partition ID as a KDF input, and
can then be used for safely for further derivations by the user, without risks
to derive the same keys as other users. This is enforced directly by the
tfm_builtin_key_loader driver.
If the NS client ID feature is disabled, all NS callers share a partition ID
of -1, and therefore will share a platform key and be therefore be able
to derive the same keys as other NS callers.
For keys that are not exposed outside the device, this is transparent to the service that is using the key derivation, as they have no access to the builtin key material and cannot distinguish between keys derived directly from it and keys derived from the platform key. For some builtin keys, deriving platform keys is not acceptable, as the key is used outside the device (i.e. the IAK public key is used to verify attestation tokens) so the actual builtin key is used.
The decision has been taken to derive platform keys for any key that can be used
for key derivation (PSA_KEY_USAGE_DERIVE), and not derive platform keys
otherwise. For builtin keys that do not derive platform keys but are directly
used, care must be taken with access control where multiple partitions have
access to the same raw key material.
TF-PSA-Crypto transparent builtin keys
TF-PSA-Crypto does not natively support transparent builtin keys (transparent
keys are keys where the key material is directly accessible by the PSA Crypto
core), so some modifications had to be made. Opaque keyslots have the same basic
structure as standard transparent key slots, and can be passed to the functions
usually reserved for transparent keys, though this is a private implementation
detail of the TF-PSA-Crypto library and is not specified in the driver interface.
Therefore, the only modification required currently is to allow keys that have
the location TFM_BUILTIN_KEY_LOADER_KEY_LOCATION to be passed to the
functions that usually accept transparent keys only, i.e. with the location
PSA_KEY_LOCATION_LOCAL_STORAGE. This is due to the fact that the standard
assumption of the PSA Crypto core is that, if a driver that provides an
additional location, will also provide dedicated cryptographic mechanisms to act
on those keys, but this is not the case of the tfm_builtin_key_loader, as it
just provides a mechanism to load keys (which act as a transparent key with
local storage, once loaded), but TF-PSA-Crypto does not support such “transparent
builtin key” concept. Note that the modifications on TF-PSA-Crypto are relying
on non standard implementation details hence this particular integration can
change between releases [3].
Using Opaque PSA crypto accelerators with TF-M
For platforms which have a cryptographic accelerator which has a corresponding
Opaque PSA crypto accelerator driver, the TF-M builtin key loader driver can be
disabled using the -DCRYPTO_TFM_BUILTIN_KEYS_DRIVER=OFF cmake option. The
platform can then redefine the HAL function
tfm_plat_builtin_key_get_desc_table_ptr to point to a table where the
location and slot number of the keys corresponds instead to the opaque driver.
The PSA driver wrapper will then route the calls into the opaque driver, with no
other changes needed. If the description table is altered but the builtin key
loader driver is not disabled, it is possible to mix software builtin keys with
keys stored in opaque accelerators on a per-key level. Note that because the key
policy enforcement via tfm_plat_builtin_key_get_desc_table_ptr is currently
applied by the builtin key loader driver, other opaque drivers must apply either
this policy or their own policy (Though this may be changed in future).
