Floating-Point Support
TF-M adds several configuration flags to control Floating point (FP) [1] support in TF-M Secure Processing Environment (SPE) and Non Secure Processing Environment (NSPE).
  • Support FP in SPE or NSPE.
  • Support FP Application Binary Interface (ABI) [2] types: software, hardware. SPE and NSPE shall use the same FP ABI type.
  • Support lazy stacking enable/disable in SPE only, NSPE is not allowed to enable/disable this feature.
  • Support GNU Arm Embedded Toolchain [3]. GNU Arm Embedded Toolchain 10.3- 2021.10 and later version shall be used to mitigate VLLDM instruction security vulnerability [4].
  • Support both IPC [5] and SFN [11] models in TF-M.
  • Support Armv8-M mainline.
  • Support isolation level 1,2,3.
  • Support Arm Compiler for Embedded [10]. Arm Compiler for Embedded 6.17 and later version shall be used to mitigate VLLDM instruction security vulnerability [4].
  • Does not support use FPU in First-Level Interrupt Handling (FLIH) [6] at current stage.
Please refer to Arm AN521 or AN552 platform as a reference implementation when you enable FP support on your platforms.
Alternatively, if you intend to use FP in your own NSPE application but the TF-M SPE services that you enable do not require FP, you can set the CMake configuration CONFIG_TFM_ENABLE_CP10CP11 to ON and ignore any configurations described below.
CONFIG_TFM_DISABLE_CP10CP11 can be set to ON to disable CP10/CP11 coprocessors in cases when it’s expected that FPU must not be used neither by secure nor by non-secure images.
GNU Arm Embedded Toolchain 10.3-2021.10 may have issue that reports '-mcpu=cortex-m55' conflicts with '-march=armv8.1-m.main' warning [8]. This issue has been fixed in the later version.
FP ABI type for SPE and NSPE
FP design in Armv8.0-M [9] architecture requires consistent FP ABI types between SPE and NSPE. Furthermore, both sides shall set up CPACR individually when FPU is used. Otherwise, No Coprocessor (NOCP) usage fault will be asserted during FP context switch between security states.
Secure and non-secure libraries are compiled with COMPILER_CP_FLAG and linked with LINKER_CP_OPTION for different FP ABI types. All those libraries shall be built with COMPLIER_CP_FLAG.
If FP ABI types mismatch error is generated during build, please check whether the library is compiled with COMPILER_CP_FLAG. Example:
target_compile_options(lib
    PRIVATE
        ${COMPILER_CP_FLAG}
CMake configurations for FP support
The following CMake configurations configure COMPILER_CP_FLAG in TF-M SPE.
  • CONFIG_TFM_ENABLE_FP is used to enable/disable FPU usage.
    FP support
    off (default)
    FP disabled
    on
    FP enabled
CONFIG_TFM_FLOAT_ABI depends on CONFIG_TFM_ENABLE_FP. If CONFIG_TFM_ENABLE_FP is set ``CONFIG_TFM_FLOAT_ABI is automatically set to hard.
If TF-M SPE is built with CONFIG_TFM_ENABLE_FP=on, then SPE takes care of enabling floating point coprocessors CP10 and CP11 on the NS side. This is done to avoid NOCP usage fault.
  • CONFIG_TFM_LAZY_STACKING is used to enable/disable lazy stacking feature. This feature is only valid for FP hardware ABI type. NSPE is not allowed to enable/disable this feature. Let SPE decide the secure/non-secure shared setting of lazy stacking to avoid the possible side-path brought by flexibility.
    0FF
    Disable lazy stacking
    ON (default)
    Enable lazy stacking
  • CONFIG_TFM_FP_ARCH specifies which FP architecture is available on the target, valid for FP hardware ABI type.
    FP architecture is processor dependent. For GNUARM compiler, example value are: auto, fpv5-d16, fpv5-sp-d16, etc. For armclang, example value are: none, softvfp, fpv5-d16, fpv5-sp-d16, etc.
    This parameter shall be specified by platform in preload.cmake. Please check compiler reference manual and processor hardware manual for more details to set correct FPU configuration for platform.
  • CONFIG_TFM_FP_ARCH_ASM specifies the target FPU architecture name shared by Arm Compiler armasm and armlink. It is only used in the --fpu= argument by Arm Compiler and shall be aligned with CONFIG_TFM_FP_ARCH.
    FP architecture is processor dependent. For armasm and armlink, example value are: SoftVFP, FPv5_D16, etc.
Copyright (c) 2021-2023, Arm Limited. All rights reserved.
