Advisory TFMV-4
NSPE may access secure keys stored in TF-M Crypto service in Profile Small with Crypto key ID encoding disabled.
CVE-2021-40327
Public Disclosure Date
22nd Nov, 2021
TF-M v1.4.0
Configurations
Profile Small
In Profile Small, secure keys stored in Crypto service can be leaked to NSPE if NSPE acquires secure key IDs.
Commit 42e77b561fcfe19819ff1e63cb7c0b672ee8ba41 and v1.4.1
N/A
TF-M Profile Small disabled Crypto key ID encoding with key owner client ID in TF-M v1.4.0 release.
When the Crypto key is stored into TF-M Crypto service, the key ID is not encoded with the client ID of key owner in Profile Small in TF-M v1.4.0. Therefore, TF-M Crypto service is unable to distinguish or validate owners of keys in Profile Small. NSPE can access the keys belonging to SPE in Profile Small in some scenarios.
In TF-M v1.4.0, TF-M Crypto service by default relies on two mechanisms to validate key owners in key management.
  • TF-M Crypto service maintains a key handle array. When a key is stored in Crypto service, the key ID and the key owner client ID are stored in the array. When a caller requests to access a key, TF-M Crypto service validates the request by comparing the caller client ID with the stored key client ID.
  • Mbed TLS stores a special structure encoded by key owner client ID and the key ID. When a caller requests to access a key, Mbed TLS validates the request by comparing the caller client ID with the key client ID stored in that structure.
Secure clients are not isolated from each other in Profile Small and it doesn’t require to validate key owner client ID between secure clients. Therefore, in TF-M v1.4.0, Profile Small disabled both mechanisms above to optimize the key storage size. The key directly or indirectly stored via psa_import_key() is not encoded with key owner client ID.
However, it also disables the validation of NS client ID when a NS client accesses keys stored in TF-M Crypto. NS clients can call `psa_export_key() to access secure clients’ keys stored via psa_import_key(), if NS clients acquire the key ID of secure clients.
Only TF-M Profile Small is impacted. All the other configurations or Profiles are not affected.
Analysis of RoT services in Profile Small
TF-M Profile Small enables Internal Trusted Storage (ITS), Crypto and Initial Attestation by default. The following analysis focuses on the impact on RoT services in Profile Small.
  • ITS service doesn’t create or store its own key in Crypto service. It is not impacted directly.
  • Crypto service key derivation may be impacted.
    • psa_key_derivation_output_key() eventually stores the derived key in Crypto service. The stored derived keys can be accessed by a NS client if the NS client acquires the derived key ID value.
    • Platform specific implementation may store Hardware Unique Key (HUK) into Crypto service for key derivation from HUK via psa_import_key().
      • Platform driver may import HUK as a temporary key into Crypto service during derivation and close the temporary key when derivation completes.
        If a NS client preempts the derivation and calls PSA Cryptography API to access temporary HUK data stored in Crypto service, the access will be captured by TF-M re-entry detection and rejected by TF-M SPE.
      • Platform driver may permanently store HUK via Crypto service for derivation and the key is still managed by Crypto service when NSPE is running.
        NS client can access HUK data via PSA Cryptography API if it acquires the key ID of stored HUK.
  • Symmetric key algorithm based Initial Attestation temporarily stores symmetric Initial Attestation Key (IAK) in Crypto service during Initial Attestation Token generation. It imports symmetric IAK into Crypto service during generation and removes it from Crypto service when generation completes.
    If a NS client preempts the generation and calls PSA Cryptography API to access the temporary IAK data stored in Crypto service, the access will be captured by TF-M re-entry detection and rejected by TF-M SPE.
    Therefore, Initial Attestation is not impacted directly.
Impact on Profile Small default implementation
Default Profile Small RoT services don’t initially call Crypto key derivation or store any secure key into Crypto service.
According to the analysis of RoT services above, device HUK can be accessed by NS clients and leaked to NSPE, in Profile Small default implementation, when all the following conditions are met.
  • Platform specific implementation stores HUK in Crypto service, initially or during a derivation requested by NS client.
  • HUK is still stored in Crypto service when NSPE is running.
  • An NS client acquires the key ID of HUK in Crypto service and accesses HUK key via PSA Cryptography API.
Other vulnerabilities are not found yet so far.
Impact on vendor RoT services
If a vendor RoT service is integrated in Profile Small, its keys stored via psa_import_key() or derived from psa_key_derivation_output_key() can be accessed by NS client and leaked to NSPE when both following conditions are met.
  • The secure key is stored in Crypto service when NSPE is running.
  • An NS client acquires the key ID and accesses the key via PSA Cryptography API.
How NS client can acquire secure key ID is related to key management implementation of the underlying crypto library in TF-M Crypto service. With default Mbed TLS, NS hackers can import a NS key at first to obtain the rough base value of Mbed TLS key slots and then try a smaller subset of key ID values by brute-force.
This issue has been fixed by enforcing Mbed TLS key ID encoding with key owner client ID to be enabled.
This patch intended to optimize TF-M Crypto service key handle array and coincidentally fixed the issue.
v1.4.1 fixed this issue as a patch release.
