Memory-mapped IOVECs
This document describes briefly the Memory-mapped IOVECs at higher isolation levels (isolation levels 2 and 3). The MM-IOVEC is fully described in FF-M v1.1 [FF-M-1.1-Extensions].
Key terms:
IL1: Lowest isolation level
IL2 / IL3: Higher isolation levels
SSM - Secure Shared Memory: refers to a block of secure memory that is available to RoTs but is not private to any single RoT.
FF-M v1.1 introduced MM-IOVEC functionality. Its initial implementation in TF-M restricted the capability to isolation level 1. The build system displays a warning banner when MM-IOVEC is enabled.
Problem statement
The current MM-IOVEC mechanism is restricted to partitions operating at IL1. This limitation prevents efficient transfer of large payloads for partitions at higher isolation levels.
The objective is to enable MM-IOVEC support for IL2/IL3 partitions while preserving isolation guarantees and without affecting security properties.
- Reasons to extend support to higher isolation levels are:
Process large payloads that do not fit in the client buffers
Enable multiple actors to process and forward the ‘original’ vectors
Proposed solution
Remove the tfm_invalid_config check for TFM_ISOLATION_LEVEL GREATER 1 and
PSA_FRAMEWORK_HAS_MM_IOVEC. This change enables MM-IOVEC for IL2 and IL3.
No changes to the SPM implementation are required. However additional responsibilities are introduced for relevant partitions.
- This solution enables:
mapping and passing of Secure Shared Memory, for example a mmio flash
mapping and passing NSPE buffers
This document uses the Generic TF-M Threat Model to assess the impact of the solution.
Targeted Threat analysis
This section presents a simplified text-based data flow sequence (DF) to help analyse whether boundaries, data classification and actors need to change.
DF-1..DF-5 - Data provided by NSPE
DF-1 NS sends a request to SPE with iovecs (already covered)
DF-2 - 1st partition
the partition maps the input/output vectors
processes the data
temporarily copies the NS vector pointers in own memory/stack and forward those to another partition via
psa_call()unmap the vectors
DF-3 - 2nd partition + the partition maps the input/output vectors + processes the data + unmap the vectors
DF-4 - 1st partition + the partition maps the input/output vectors + processes the data + unmap the vectors
DF-5 NS resumes with the processed data in the output vectors
DF-6..DF-10 - Data provided by SPE
DF-6 NS sends a request to SPE WITHOUT iovecs (already covered)
DF-7 - 1st partition
the partition process the request, prepares the SSM references
processes the data
temporarily copies the SSM pointers into vectors in own memory/stack and forward those to another partition via psa_call()
unmap the vectors
DF-8 (equal to DF-3) - 2nd partition
processes the data
unmap the vectors
DF-9 - 1st partition
processes the data
unmap the vectors
DF-10 NS resumes with the processed data in the output vectors
We analyze if with the DF above the threats scenario is worsened. We assume IL3. The NSPE to SPE interactions are already covered by the Generic TF-M Threat Model. We limit the analysis for the MM-IOVEC mapping/unmapping between the partitions.
DF-1, DF-6 Already covered in Generic TF-M Threat Model
DF-2, DF-3, DF-4, DF-7, DF-8, DF-9 Not covered in the Generic TF-M Threat Model because of the definitions of trusted boundaries (see section https://trustedfirmware-m.readthedocs.io/en/latest/security/threat_models/generic_threat_model.html#data-flows-inside-spe-informative)
Spoofing The caller partition may try to access and use another’s partition identity
Not a threat. The caller partition’s identity is assigned and checked by SPM and cannot be directly provided.
Tampering The caller partition may try to change or modify persistent data
Not a threat. We trust the partition to not behave as an attacker (see FF-M).
Also, the caller partition can already map/unmap vectors from NS or from SSM by “design (of the memory)”.
Repudiation The caller partition may try to perform prohibited operations in a system that lacks the ability to trace the operations.
Not a threat. We trust the partition to behave responsibly.
Information disclosure The caller partition may try to access a file or data it was not granted access to.
Allowing the mapping/unmapping does not change the isolation rules. Thus if unprivilege code tries to access priv or another unpriv data, the system raises a Fault. Also, the caller partition can already map/unmap vectors from NS or from SSM by “construction”.
DoS Not covered in the threat model
Out of scope as per TF-M Generic Threat Model.
Elevation of privilege The caller partition may try to gain privileged access to the data
Not a threat. We trust the partition to not behave as an attacker.
Interaction with the isolation model analysis
According to FF-Mv1.1, in an implementation with IL2, IL3, MM-IOVEC provides a mechanism that may conflict with the isolation rules.
Possible conflict
With IL3 a Secure Partition is not permitted to access another Secure Partition’s Private data. MM-IOVEC may provide a mechanism for one Secure Partition to access the other’s Private data.
SPM implemented in TF-M ensures that:
the mapped vectors fulfill the requirements for the callee partition by testing the vectors with
cmse_check_address_rangewhen mapping/unmappingthe execution environment for ARoT provided by SPM is such that a ARoT cannot access data belonging to other ARoTs. This is enforced regardless the MM-IOVEC support (PSA_FRAMEWORK_HAS_MM_IOVEC)
Possible conflict
In a system that implements isolation rule I6 (see [FF-M] §3.1.5), only the SPM is permitted to access memory in another protection domain when required. MM-IOVEC can provide access from a Secure Partition directly to client memory.
Isolation rule I6 is not implemented.
Possible imprecise mapping
The mapping mechanism can provide more access than is strictly required.
We must take into account the hardware limitations that can impact mapping precision. Any client of the API must take steps to mitigate the MPU granularity, for example by aligning the buffer and buffer size in memory. It is IMPLEMENTATION DEFINED how such imprecise mappings are handled by the implementation. The decision to permit imprecise mappings depends on the security requirements for the system, and the nature of the additional access.
An implementation that provides MM-IOVEC functionality must document its behavior when an input or output vector mapping is imprecise.
The services designed and implemented to handle such payloads may need to provide platform hooks to correctly set the MPU alignment for the SSM. Alternatively, the MPU can be set once at init stage to correctly bound the region limits.
Discussion
The FF-M architecture assumes that RoT partitions do not behave maliciously and are implemented correctly. Through secure boot, such RoTs are authenticated.
Based on the above, there is no need to introduce new trust boundaries between partitions’ domains.
The assets protection does not change when the mapping/unmapping is performed, because the isolation boundaries are enforced (take place) when SPM changes the running partition and is independent from the MM-IOVEC mapping.
Accessing NS buffers with IL3 is not any different from IL1 since the isolation domain b/w NS and the PRoT-ARoT does not change.
Accessing non-private shared secure data does not conflict with the isolation domains, that is, there’s no direct data sharing b/w partitions.
SPM ensures that the vectors can be accessed by the partitions according to their boundaries settings, irrespective of the PSA_FRAMEWORK_HAS_MM_IOVEC capability.
When mapping/unmapping is required, additional memory checks are performed to ensure the calling partition can safely access the given vectors.
The non-private shared secure regions need to have the correct attributes for the mapping partitions to be consumed.
Conclusion
Based on the analysis and discussion above, we don’t consider that an update in the Threat Model is required.
Relaxing the usage of MM-IOVEC to higher isolation level does not change the threat landscape and does not violate the isolation rules.
Build options and configs
Unchanged
Remarks
PRoT and ARoT must not access vectors after unmapping.
