Advisory TFMV-11
Incorrect FMP Header Fragment Reconstruction Allows Attacker-Controlled Firmware Version Values
Requested, being assigned
Public Disclosure Date
Aug 03, 2026
TF-M v2.2.0 and v2.3.0 inclusive
Configurations
Only Corstone-1000 platform
Fragmented supplied FMP header skips firmware version checks for firmware updates in some scenarios
d92781c5b966ee700ddaa9525230e677789def96
Credits
Undisclosed
The sequence below applies only for Corstone-1000 platform. The requester for a firmware update (FWU) provides metadata along with the image to be used for update. The FWU implementation checks the candidate firmware version against the current running version. Only newer versions are allowed. When carrying out those checks, internal copies of incoming metadata are performed. The requester is allowed to supply metadata and data in multiple calls and the implementation keeps track of the incoming chuncks in the whole sequence. When the incoming metadata is supplied through multiple calls, the implementation incorrectly overwrites and reconstruct the FMP header. This FMP header contains the requested firmware version. Subsequent calls of partial FMP header lead to overwrite of firmware version which ultimately can be used as an exploit to bypass version checks. This mechanism is, however, not the only single point of verification. During the image loading sequence, further version checks are performed. Counters are used within the signed image for those verification. When non-volatile counters are not implemented, then the backup verification checks cannot take place. Some type of images within the firmware capsule update are susceptible to the above flaw.
The firmware version checks, combined with missing security counters for some images, lead to unverified, attacker-controlled firmware updates.
Perform correct storage of the incoming partial FMP header.
See commit d92781c5b966ee700ddaa9525230e677789def96.
