First Things First
Prerequisite
Trusted Firmware M provides a reference implementation of the Platform Security Architecture (PSA) specifications, aligning with PSA Certified guidelines. It is assumed that the reader is familiar with the specifications that can be found here.
The current TF-M implementation on Armv8-M leverages TrustZone for Armv8-M so a good understanding of the v8-M architecture is also necessary. A good place to get started with Armv8-M is developer.arm.com.
Build and run instructions
Trusted Firmware M source code is available on git.trustedfirmware.org.
To build & run TF-M:
To port TF-M to a another system or OS, follow the OS Integration Guide
Contributing Process contains guidance on how to contribute to this project.
Set up build environments
TF-M officially supports a limited set of build environments and setups. In this context, official support means that the environments listed below are actively used by team members and active developers, hence users should be able to recreate the same configurations by following the instructions described below. In case of problems, the TF-M team provides support only for these environments, but building in other environments can still be possible.
The following environments are supported:
  1. version supported:
    Ubuntu 18.04 x64+
  2. install dependencies:
sudo apt-get install -y git curl wget build-essential libssl-dev python3 \
python3-pip cmake make
  1. verify cmake version:
cmake --version
Please download CMake version 3.21 or later from https://cmake.org/download/.
  1. add CMake path into environment:
export PATH=<CMake path>/bin:$PATH
Install python dependencies
Clone the TF-M source code, and then install the TF-M’s additional Python dependencies.
  1. get the TF-M source code:
git clone https://git.trustedfirmware.org/TF-M/trusted-firmware-m.git
  1. TF-M recommends installing dependencies in a venv
# Setup python venv for the project
python3 -m venv .venv
# NOTE: If your system python install version is <3.10 you can use `uv <https://docs.astral.sh/uv/getting-started/installation/#standalone-installer>` to setup your .venv
uv venv --python 3.12
source .venv/bin/activate
cd </trusted-firmware-m>
# `-e` installs modules and scripts in editable/development mode
pip install -e .
# NOTE: If you've used `uv` to setup your `.venv`, prepend the `pip` commands with `uv`
uv pip install -e .
Install a toolchain
To compile TF-M code, at least one of the supported compiler toolchains have to be available in the build environment. The currently supported compiler versions are:
Arm Compiler (minimum v6.21)
  • Download the standalone packages from here.
  • Add Arm Compiler into environment:
export PATH=<ARM_CLANG_PATH>/bin:$PATH
export ARM_PRODUCT_PATH=<ARM_CLANG_PATH>/sw/mappings
  • Configure proper tool variant and license.
When compiling for a Cortex-M52 target, a Cortex-M85 target, or with an -mcpu=<name> option that includes the +pacbti feature modifier, and when configured without User based Licensing, the compiler could incorrectly report one of these errors:
  • Cortex-M52 is not available with the current toolkit edition and license
  • Cortex-M85 is not available with the current toolkit edition and license
The use of -target-feature +pacbti is disallowed in this variant of Armclang. Please use Armclang version 6.24+ which does not have this issue.
GNU Arm compiler (minimum v12.2.Rel1)
  • Download the GNU Arm compiler from here.
  • Add GNU Arm into environment:
export PATH=<GNU_ARM_PATH>/bin:$PATH
IAR Arm compiler (minimum v9.30.1)
  • Download IAR build tools from here.
  • Add IAR Arm compiler into environment:
export PATH=<IAR_COMPILER_PATH>/bin:$PATH
Arm Toolchain for Embedded (minimum v20.1.0)
  • Download the Arm Toolchain for Embedded (ATfE) from here.
  • Add ATfE into environment:
export PATH=<ATFE_PATH>/bin:$PATH
Not all platforms support this toolchain. Please refer to a platform documentation or check with the platform owner.
Build AN521 regression sample
Here, we take building TF-M for AN521 platform with regression tests using GCC as an example:
Get the TF-M tests source code:
git clone https://git.trustedfirmware.org/TF-M/tf-m-tests.git
Build SPE and NSPE.
cd </tf-m-tests/tests_reg>
cmake -S spe -B build_spe -DTFM_PLATFORM=arm/mps2/an521 -DCONFIG_TFM_SOURCE_PATH=<TF-M source dir absolute path> \
      -DCMAKE_BUILD_TYPE=Debug -DTFM_TOOLCHAIN_FILE=<TF-M source dir absolute path>/toolchain_GNUARM.cmake \
      -DTEST_S=ON -DTEST_NS=ON
cmake --build build_spe -- install
cmake -S . -B build_test -DCONFIG_SPE_PATH=<tf-m-tests absolute path>/tests_reg/build_spe/api_ns \
      -DCMAKE_BUILD_TYPE=Debug -DTFM_TOOLCHAIN_FILE=<tf-m-tests absolute path>/tests_reg/build_spe/api_ns/cmake/toolchain_ns_GNUARM.cmake
cmake --build build_test
Run AN521 regression sample
Run the sample code on SSE-200 Fast-Model, using FVP_MPS2_AEMv8M provided by Arm Development Studio.
Arm Development Studio is not essential to develop TF-M, you can skip this section if don’t want to try on Arm develop boards.
  1. Install Arm Development Studio to get the fast-model.
    Download Arm Development Studio from here.
  2. Add bl2.axf and tfm_s_ns_signed.bin to symbol files in Debug Configuration menu.
<DS_PATH>/sw/models/bin/FVP_MPS2_AEMv8M  \
--parameter fvp_mps2.platform_type=2 \
--parameter cpu0.baseline=0 \
--parameter cpu0.INITVTOR_S=0x10000000 \
--parameter cpu0.semihosting-enable=0 \
--parameter fvp_mps2.DISABLE_GATING=0 \
--parameter fvp_mps2.telnetterminal0.start_telnet=1 \
--parameter fvp_mps2.telnetterminal1.start_telnet=0 \
--parameter fvp_mps2.telnetterminal2.start_telnet=0 \
--parameter fvp_mps2.telnetterminal0.quiet=0 \
--parameter fvp_mps2.telnetterminal1.quiet=1 \
--parameter fvp_mps2.telnetterminal2.quiet=1 \
--application cpu0=<build_spe>/api_ns/bin/bl2.axf \
--data cpu0=<build_test>/tfm_s_ns_signed.bin@0x10080000
The log is output to telnet by default. It can be also redirected to stdout by adding the following parameter.
--parameter fvp_mps2.UART0.out_file=/dev/stdout
To automatically terminate the fast-model when it finishes running, you can add the following parameters:
--parameter fvp_mps2.UART0.shutdown_on_eot=1
After completing the procedure you should see the following messages on the DAPLink UART (baud 115200 8n1):
#### Execute test suites for the Secure area ####
Running Test Suite PSA protected storage S interface tests (TFM_S_PS_TEST_1XXX)...
> Executing 'TFM_S_PS_TEST_1001'
Description: 'Set interface'
TEST: TFM_S_PS_TEST_1001 - PASSED!
> Executing 'TFM_S_PS_TEST_1002'
Description: 'Set interface with create flags'
TEST: TFM_S_PS_TEST_1002 - PASSED!
> Executing 'TFM_S_PS_TEST_1003'
Description: 'Set interface with NULL data pointer'
TEST: TFM_S_PS_TEST_1003 - PASSED!
> Executing 'TFM_S_PS_TEST_1005'
Description: 'Set interface with write once UID'
TEST: TFM_S_PS_TEST_1005 - PASSED!
Tool & Dependency overview
To build the TF-M firmware the following tools are needed:
  • C compiler of supported toolchains
  • CMake version 3.21 or later
  • Git
  • gmake, aka GNU Make
  • Python >=v3.11
  • [Optionally] uv
Dependency chain
@startuml
 skinparam state {
   BackgroundColor #92AEE0
   FontColor black
   FontSize 16
   AttributeFontColor black
   AttributeFontSize 16
 state fw as "Firmware" : TF-M binary
 state c_comp as "C Compiler" : C99
 state python as "Python" : v3.x
 fw --> c_comp
 fw --> CMake
 CMake --> gmake
 CMake --> Ninja
 fw --> cryptography
 fw --> pyasn1
 fw --> yaml
 fw --> jinja2
 fw --> cbor2
 fw --> click
 fw --> imgtool
 c_comp --> GCC
 c_comp --> CLANG
 c_comp --> IAR
 cryptography --> python
 pyasn1 --> python
 yaml --> python
 jinja2 --> python
 cbor2 --> python
 click --> python
 imgtool --> python
 kconfiglib --> python
@enduml
Next steps
Here are some next steps for exploring TF-M:
